radiator hose
radiator hose
anybody have part numbers for radiator hoses that could work on an ls1 in a 71 lemans? radiator upper/inlet is located driver side and lower/outlet is located passenger side. the existing radiator is plenty large enough. was trying to save some time on the hoses. thanks!
I used the stock 03 truck hoses on my 70. Top fit perfect and had to shorten the lower about 3" at the pump. Used a little WD-40 to slip the hoses over the radiator inlet and outlet.
