Compression Ratio Math Check Please!
Just want to confirm my compression ratio for my LQ4 build:
Stock bore/stroke/piston LQ4
243 heads milled .017
Stock .051 thickness head gasket
I'm getting 11.1:1
Can anyone confirm my math?
Thanks in advance!
I'm getting 11.1:1
Thanks in advance!
Valve relief on the pistons (like 4cc)? Do you know how far out of the hole the pistons are (deck clearance)? What size compression chambers on the heads? Is that about 60cc?
dont mean to hijack but i have the same question
heres my specs:
pistons -6cc
799 heads milled .019
cc head @ 62cc
piston to deck -.013
.075 between piston and flat of head
3.905 bore
.050 thick gasket
any help would be great
thanks in advance
heres my specs:
pistons -6cc
cc head @ 62cc
3.905 bore
.050 thick gasket
thanks in advance
Here is a good web site to bookmark that will calculate your compression ratio:
http://www.kb-silvolite.com/calc.php?action=comp
Thank you! I'll bookmark that for the next build!
