Fazz73jr
03-26-2012, 10:53 PM
Car is the 95z in the sig. Car and trans has about 127k on it about 24k since the 383. just recently when i come to a stop and relase the clutch pedal ive been noticing the car vibrates alot. if i push the clutch pedal back in it goes back down to normal.
All gears except reverse go in fine with no grinding what so ever. reverse gears been bad since i got the car at 104k. i have to put it in another gear first then quickly shift to reverse so it wont grind. also ive noticed 5th and 6th whining lately. but i just figured it was the diff from a few track outtings.:drive:
What do you guys think? bearing going out? Thanks in advance :)
Heres a video. although i dont know how much help it will be. ill try to get a better camara.
http://youtu.be/f1QwKLwn_W4
