Couple questions about frost tune
I have 99 z28 with pacesetter lt's, race style and off road y and magna flo catback and slp lid, fast toys cold air, 160 thermostat and the hypertech powerpac, this has the dyno and dionostics and 1/4 mile tester also. I have taller tires ,so far hyperpac has worked for all these things accept for the egr air pump rear 02 lights . I was going to sell the hyper pac till i found out they want $200 to return to stock . So my question is is ther any deals on just turning theys lights off and if ther turned of will i still be able to use the hyperpac or am i stuck with one or the other or if i have the full tune can i still use the montoring and test parts of the hyperpac. And also i have deleated the abs and tcs can thease lights be turned off or is that anything to do with the pcm, I know the hyperpac dose not pick up any codes for them . Thanks any comments that may help welcome
Only answers I can give are;
The TC and ABS lights will need to have the traces cut on the Cluster PC board...or completely de-solder the bulbs. Might not be the right way, but that's what I did. I could find no other way to turn them off.
