2001 mustang with 6.0 alt wiring help
Old 03-27-2012, 03:52 PM
dirty39212's Avatar
Default 2001 mustang with 6.0 alt wiring help
I have done a search but didn't find anything on this! My mustang is a 2001 mustang GT and the stock alt plug has 2 wires and the 6.0 alt has a 2 wire plug. Can i simply connect the 6.0 alt plug to my factory wiring? I assume one wire is a keyed 12 volt and the other is for the guage I guess. Any help would be appreciated!
Old 03-28-2012, 07:13 PM
dirty39212's Avatar
I know there a few sn95 swap guys who have ran into this now I just need them to come in here and tell me what to do!
Old 03-28-2012, 07:20 PM
LS1MCSS's Avatar
The 6.0 should have wires for the alternator coming from the pcm. You shouldn't need to use the factory(car) wires.
Old 03-28-2012, 08:33 PM
dirty39212's Avatar
Sorry I didn't mention this will be carbed.
Old 03-28-2012, 08:34 PM
dirty39212's Avatar
Old 03-29-2012, 09:52 AM
MustangLS's Avatar
Are you using the factory underhood fuse box?
I haven't test fired mine yet but the green/red wire from the Ford fuse box is the signal wire for the alternator however everything I read said you need a resistor solidered inline with that wire to knock the voltage down. I'd have to look at my notes at home but I believe it was terminal B of the alternator plug that it goes to. The other wire is just for a gauge.
Old 03-31-2012, 12:10 AM
dirty39212's Avatar
I am using the fuse box. I think its a 4 1/5 ohm resistor but not sure. I have it wrote down in my car. So the green / red wire to terminal b on plug with a resistor then the other is for my guage. Sounds easy enough if I'm understanding correctly. I'm gonna start dropping the engine and trans in tomorrow so hopefully soon I can start figuring out the wiring! Anything I figure out I'll post it.
Quick Reply: 2001 mustang with 6.0 alt wiring help
