New LS1 Owners - Newbie Tech - biggest tires on 17'' rims
RebelMan666
03-27-2012, 04:58 PM
Im looking for a tire size that will give me a little more ground clearance for my exhaust. I'm at stock height with no plans on lowering. right now I'm running 275/40 R17. I need a good tire size for the front too. I don't want to have to cut anything. thanks
conan
03-27-2012, 10:20 PM
How wide are your rims ?
RebelMan666
03-28-2012, 02:10 PM
9 or 9.5 I can't remember. I have the stock ws6 rims and then another set of enkei rims.
JD_AMG
03-28-2012, 03:40 PM
I know this isn't the answer you want to hear, but if you are at stock height and having trouble with exhaust clearance then you need better exhaust... What are you running? You can tuck up true duals pretty well...
Stock WS6 wheels are 17x9.
RebelMan666
03-28-2012, 03:49 PM
I have two cutouts after the headers followed by a magnaglow catback. I'm having a little too much scraping on the cutouts than I'd like. just trying to figure something out without losing the cutouts. I'm thinking about doing a rear cool over kit.
jimmyblue
03-28-2012, 04:08 PM
I have 285/40s on SS 10-spokes and to me it looks just
shy of "too wide". Not a whole lot of height added.
Almost impossible to find a Y or Z rated tire in anything
taller than a 40 series.
Might consider going up in rim diameter instead of looking
just to the rubber.
The Mighty Texan
03-28-2012, 04:19 PM
I agree with JD the exhaust is the problem here, it can be tucked up more then plenty for stock.
chasgiv3
03-28-2012, 05:14 PM
I put Mickey Thompson ET Street Radials II on the back and they are noticably taller.
Overall Diameter = 27.2
http://www.mickeythompsontires.com/strip.php?item=ETStreetRadialII
Also if you switch to a QA1 shock you can adjust the height with that.
RebelMan666
03-29-2012, 05:56 AM
what's the tire life on those mickeys? my car is a DD, does that change anything?
udienow
03-29-2012, 08:30 AM
They do make low profile cutouts that should fit better.... will probably cost less than new tires too.
RebelMan666
03-29-2012, 01:53 PM
my tires are shot now so I need to get new ones anyways
chasgiv3
03-29-2012, 02:53 PM
MT's are not good on snow or rain. DD I wouldn't recommend this tire. I only use them on nice days.
To get a tire that tall you'll need to use a truck type tire.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
