I need a bad ass degreaser to clean a rear end before install. Sugestions?
I need a bad *** degreaser to clean a rear end before install. Sugestions?
Im about to put a different rear end in my TA... Its pretty dirty as you can imagine. I need some serious *** degreaser/cleaner or ???? to clean it off... Ill probably sand blast it and put some coating on it that they use for them and transmissions.. (forget the name)... What would you use? The rear has nothing on it, no suspension/brakes or LCAs...
Actually a pressure washer might be your best bet. If you put the right tip on the pressure washer gun, it will take gum off of concrete. So....grease shouldnt be a problem.
Ive got a 1200psi electric husky pwr washer I use on my car with the foam gun... Ill probably do that after its soaked for a bit...
the rear end is a 10 bolt 3.42 from a 6speed car... I have 3.23s now but the lsd is toast and I dont have the cash for the Moser I want...
I took it out tonight and soaked it and hit it once with the washer.. sprayed it again and then put it back in the garage.. Ill finish tomorrow when I can see wtf Im doing... im going to sand blast it too so it looks nice and neat...
whats the name of the paint the use on these types of parts? I hear its some mean ****... cant remember the name.
