MonmouthCtyLS7
03-27-2012, 11:04 PM
The car was originally a 95, I swapped the LS1 in and LS front end, what is needed to convert to DRL...is this all I would need ?
http://www.ws6project.com/user_stor/catalog/98-02-f-body-gm-drl-bulb-socket/
WhiteBird00
03-28-2012, 09:35 AM
No, that is just the bulb socket. To convert to OEM DRLs would involve buying a DRL module ($220 at the dealer) and rewiring everything between the turn signal switch and the front lamps.
A much simpler (and less expensive) solution is to get the universal DRL module from webelectricproducts.com. It provides the same DRL functionality as the OEM module but only costs $40 and takes much less work to install.
