Need some suggestions on a quick spooling twin setup for a 4.8
Old 03-28-2012, 06:46 AM
groundczero's Avatar
Default Need some suggestions on a quick spooling twin setup for a 4.8
Ok I am in process of putting a 4.8 in my 52 studebaker starlight commander.
I want to go forced induction, but I am not going crazy big HP.
I am aiming between 400-450 hp engine.
I am running a 4l60e (not to worried about it breaking since car is only 3000lbs, and not a sticky tire car.
The only other mod I am making to up HP is a 04z06 cam, with propper supporting mods.
Due to engine bay, and wanting to run exhaust through the side of the cars body, a twin setup is preffered.
I am looking to have something that will spool fast since this is a DD.
I was thinking getting 2 turbos off a WRX or something like that.
Input please.
Old 03-28-2012, 06:50 AM
chuntington101's Avatar
https://ls1tech.com/forums/forced-in...76r-390ci.html
...maybe with GT28s insteead of GT30s?......
Chris.
Old 03-28-2012, 06:59 AM
30th t/a's Avatar
Here is what I am going to run on my 5.7. They are small turbo's. Im hoping for as little lag as possible and 500rwhp with 8psi springs on the stock 5.7 LS1
GARRETT T3 / T04B "S" trim (130-350 HP)
TURBO SPECIFICATIONS:
compressor wheel: 48.4 / 69.9 mm 48 "S" Trim
compressor housing: 0.60 a/r T04B
center section: oil cooled journal bearings
Turbine wheel: 68 trim (stage1)
Turbine housing .48 a/r (.63 a/r upgrade available for 280+ HP)
Quick Reply: Need some suggestions on a quick spooling twin setup for a 4.8
