Cadillac CTS-V - V pulls right under hard acceleration
jakefrc
03-28-2012, 02:09 PM
My '04 V pulls to the right under hard acceleration, the harder you hit the pedal the harder it pulls, then when you let off, it pulls to the left, when neutral acceleration, it is straight. Any ideas? It has 90K miles on it. I'm looking at replacing the bushings in the rear trailing arm with the turninconcepts pieces. Thanks in advance for any helpful insight.
ichpen
03-28-2012, 02:26 PM
Rear tie rods.
jakefrc
03-28-2012, 02:49 PM
Okay, are you saying they are bad, needs replaced, adjusted, etc....
wcryan
03-28-2012, 03:32 PM
Most likely your bushings. Unless you ran over something and bent it
jakefrc
03-28-2012, 05:29 PM
Alright, I'll replace the rear trailing arm bushings.
ichpen
03-28-2012, 06:51 PM
Any of the above. Have you had an alignment shop look under there recently?
6 SPEED Z
03-29-2012, 07:45 AM
Mine pulled bad with the stock diff bushing, which of course was shot. I replaced it with the CS one, and now car pulls in a straight line.
jakefrc
03-29-2012, 08:13 AM
New UMI mounts, new CS diff bushing, and full alignment, with road racing specs. Ah, wait, I had an alighnment done BEFORE the diff bushing and motor mounts.
EdmundGTP
03-29-2012, 12:54 PM
Diff bushing and motor mounts should not affect alignment.
STAGEUP
03-29-2012, 05:13 PM
Sounds like weak rear shocks to me.
