General LSX Automobile Discussion - Backpressure issues?
Master_TA
03-28-2012, 04:38 PM
I have an 02 ws6 and was wanting to do a stock manifold(for right now) into a ORY with loundmouth 1 out the back and was wanting to know if backpressure is an issue with running no cats. I do realize that this has been answered alot. But there is yes and no answers. Thanks for any help
CamaroSS27
03-28-2012, 04:53 PM
No need for back pressure and you will be fine with no cats been running no cats for years.
Master_TA
03-28-2012, 04:54 PM
thanks brother
TransAmWS.6
03-28-2012, 07:49 PM
Yup, not needed. I'm running the stock manifolds, O/R Y and a Magnaflow Catback, no issues. Your car will sound a lot better and you will pick up a little power as well.
jimmyblue
03-28-2012, 08:19 PM
(1) You don't want backpressure
(2) You're still going to have plenty. With ORY and the
SLP CME exhaust, I had enough backpressure at the
top end to blow an O2 sensor out of the hole. Sure,
the threads were a bit loose. But able to hold at
least 20-30 lb-ft of torque before feeling any yield.
That's some substantial backpressure from what's
pretty much a bare pipe setup.
Master_TA
03-28-2012, 08:52 PM
thanks guys for the heads up!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
