Generation IV External Engine - Whats the best flowing intake for L92 cylinder heads
gmchrisz71
03-28-2012, 06:39 PM
Im doing a 6.0L swap and putting on L92 cylinder heads and was wondering whats the best stock intake manifold to put on.
89ROC-Z
03-28-2012, 08:14 PM
ls3...
zummo
03-28-2012, 10:06 PM
ls3...
ls3 unless you like to spend a lot of money on a fast
bww3588
03-29-2012, 07:59 AM
Hows the flow comparison between the L76 and LS3 intake?
FryZ71
03-29-2012, 12:42 PM
L76 and LS3 intakes are the same, other than how the MAP sensor mounts.
bww3588
03-29-2012, 12:43 PM
Then why are the ls3 intakes demanding more money?
westtexasbuff
03-29-2012, 12:47 PM
Spend a few extra dollars and get the holley hi-ram if you can get it to fit.
89ROC-Z
03-29-2012, 05:44 PM
Hey westtexas, do you know if the holley high ram will fit under my ws6 glastek hood? Or maybe the edelbrock?
FryZ71
03-29-2012, 07:10 PM
I don't know...there's a few other subtle differences too, but bottom line is they flow the same.http://ls1tech.com/forums/generation-iv-external-engine/1502156-difference-between-l76-ls3-intake-manifolds.html
OP, I see the Z71 in your SN...are you putting this 6.0 in a truck? If so I'd run the L92 truck intake, it'll make more tq lower in the powerband compared to the car intakes.
MikeFSKSpeed
03-29-2012, 07:40 PM
I've had great luck with the Holley Hi Ram intakes
westtexasbuff
03-29-2012, 10:08 PM
Hey westtexas, do you know if the holley high ram will fit under my ws6 glastek hood? Or maybe the edelbrock?It will take a lot of cutting, but yes you can get it to fit. Cowl will have to be cut, windshield wipers deleted, and the hood has to be cut to clear the stock WS6 hood. The pro flow is about the same.
redtan
04-02-2012, 10:52 AM
Because they come off Camaros or Corvettes as apposed to a truck.
Same reason most LS2s from a Corvette is more expensive than say one from GTO or TBSS.
Greed4Speed
04-02-2012, 01:48 PM
An LS9 "intake" will "flow" best. :)
gmchrisz71
04-02-2012, 09:42 PM
Thanks everybody for the input. Does anyone have any dyno test for any of the intakes. im goin to look for some in the threads.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
