C5Shark
03-29-2012, 11:59 AM
I am slowly finishing up the LS3 head install on my LS2, while measuring for pushrods I noticed that as I was working my way down bank 1, the length of the pushrod required grew by about .012" or approx 1/8th of a turn of the checker.
Cylinder 1 measured the same as every cylinder on bank 2, but across the length of the head I noticed this change.
Engine is a stock shortblock/stock cam 06 LS2 in a GTO, heads are LS3, valve job and were milled by a very reputable shop, new LS7 lifters. I did notice some variation in the valve tip height which could be attributing to what I am seeing.
While this is obviously not ideal, is this something that is "common" to the LS2 deck surface? Should I pull it back apart to reinspect?
