Best cam to match with 3200 stalled dd
Old 03-29-2012, 10:00 PM
98LS1driver's Avatar
Default Best cam to match with 3200 stalled dd
I'm beefing up my dd and I have a 3200 converter stock gear nitrous car looking for the best cam to run since I daily the car and I want a noticeable lope thanks for your help
Old 03-30-2012, 05:22 AM
mjs1012's Avatar
Iv seen people have good results with the tr224 w/ a 3200 stall in a dd. might not make the biggest hp numbers but will be very streetable.
Old 03-30-2012, 05:59 AM
Would the 228r work with that stall??
Old 03-30-2012, 06:24 AM
mjs1012's Avatar
I don't see why it wouldn't. If that's the cam your thinking about call tsp and talk to them about it I'm sure they can help you out. That's one of the cams I'm concidering when the time comes.
Old 03-30-2012, 06:59 AM
Killer5.3's Avatar
I would either go with the 224 if you already have your 3200 stall or go with 3600 stall if you are set on a 228 cam.
Old 03-30-2012, 07:22 AM
ill get the 3600 and go with the 228 what lsa would be good to run the spray with?
Old 03-30-2012, 09:45 AM
00byrd's Avatar
I ran a futral f11 228/230 on a 113lsa with a 3600 worked great.
Old 03-30-2012, 10:31 AM
DallasFMS's Avatar
Get Allan here at Futral to spec you a custom cam. Use the link below and submit your car info to him and he can match the cam to your vehicle. The more information you provide the better the results.
http://futralmotorsports.com/customcamworksheet.asp
Old 03-30-2012, 10:35 AM
projectX's Avatar
Both TSP and Chris from Circle D told me that a 3000-3200 stall was recommended for my 228r cam build. So yes, if I were you I would do 224 or 228.
Old 03-30-2012, 12:15 PM
Reno's2fastestfbodys's Avatar
there is only about a 100 rpm difference between the 224r and 228r. get the 228r dont kick yourself later.
Old 03-31-2012, 01:21 AM
Killer5.3's Avatar
Unless you plan on a really big shot , cam it to run best on motor and it will work fine with the spray. I would probably go with 113 or 114 though.
