Carbureted LSX forum - attempting to get 400rwhp out of a 5.3 in my '95 z28 without breaking the bank
jerry_mcstampson
03-29-2012, 10:04 PM
Any selection choices on what I should do? as in choice of heads/cam that are decently priced. Ive already got a set of pacesetter longtubes and Holley 750
ZONES89RS
03-30-2012, 12:07 PM
You need a few things, compression, cam and RPM, can be done with nice heads. Seen some 400 rwhp dyno numbers on performancetrucks.net, sure they have the build info there.
GNCLONE
03-30-2012, 03:10 PM
what zone said
LS motors respond well to aftermarket cams - with what you already have plus some valve springs and a cam (and enough rpms) you might get to 400 at the crank.
Prorac1
03-30-2012, 04:34 PM
I think 400 at the crank with a cam and boltons would be a walk in the park. 400 at the wheels would be my guess. JMHO. Eric L
gregsss
04-12-2012, 05:51 PM
For one I hope you have a L33 5.3, they are the all aluminum 5.3 with 335 hp. Come in 04-06 silverado Z71 or the one in the SSR before they went to the 6.0
ZONES89RS
04-12-2012, 09:16 PM
Think my 03 TB is aluminum 5.3, but i am not sure if it is the flat top piston setup.
