New LS1 Owners - Newbie Tech - Should you run "regular" gas or "premium" in a WS6?
02WS6_Publix
03-29-2012, 10:21 PM
So I went to fill up my New Ws6 today after leaving the DMV (Tags and all) When i noticed I was filling up with regular gas...... Now i'm not sure how stupid of a question this is but I'll ask anyway.
Should I run premium gas instead of regular becase its a WS6?
What gas do you all run? I'm interested to know..... :nod:
conan
03-29-2012, 10:30 PM
Yes you want to run "premium" highest octane you can get at the pump. Not because its a ws6, because of the compression of the ls1 engine.
RPM WS6
03-29-2012, 10:54 PM
LS1s were designed to run optimally on 91 or higher octane. Yes, they can be run on lower octane, as there is a low octane spark table for the PCM to initiate if needed, but best performance will be achieved with premium fuel.
usafws6
03-29-2012, 11:43 PM
dont beat on it until you put premium back in it.
02WS6_Publix
03-30-2012, 08:05 AM
Thanks guys, I feel like an idiot now... but at leas I know and I can make sure I fix it from here on out.
BlackScreaminMachine
03-30-2012, 08:12 AM
Alo as a FYI, if the car has had the Tune modified, some times, more often then not tuners will remove or make the LOW Oct tables and High Octane tables one and in the same which means it does not have the ability to drop down and you could damage the motor.
So be aware of your car.
S8ER95Z
03-30-2012, 08:14 AM
The worst part is you will have bad gas mileage on the lower octane... I average 24~25mpg between fillups on 93 octane... I drop to 20~21 with 89 octane.
CamaroSS27
03-30-2012, 08:25 AM
run premium, it recommends it for our cars.
Midnight02
03-30-2012, 08:35 AM
As stated above, run premium gas in our cars -- especially if you're car has been modded and tuned.
senicalj4579
03-30-2012, 08:43 AM
Highest you can get. Mine gets 93.
Golf&GM
03-30-2012, 08:53 AM
I've noticed the same thing. A long time ago I was low on cash and filled up with 89 octane. I always reset my trip and calculate my gas milage every fill up. Running the 89 hurt my gas milage to the point where it would've been cheaper to just get the 93 octane up front.
wicked383lt1
03-30-2012, 09:20 AM
What if your car is tuned and you run 97-104 octane? Would it run just as good on 93 or better?
udienow
03-30-2012, 09:22 AM
93 Octane Shell only for me.
S8ER95Z
03-30-2012, 09:28 AM
Yep, I run 300miles a week all year long... it's definitely noticeable.
Ronny_02_WS6
03-30-2012, 09:36 AM
93 over here!!!
For anyone in CA. Try to find a station that carries 100 octane and mix it with the 91. I try to get it close to 94 or 95. Costs more at the pump but MPG is better and my car thanks me for it. Give it a try and decide for yourself.
RPM WS6
03-30-2012, 12:18 PM
If the car was tuned for 97+ octane, then it probably will not run better with 93.
However, if the car was tuned on 93 octane, then you aren't helping anything by running 97-104, and will probably notice better performance with the 93.
mjs1012
03-30-2012, 12:51 PM
i run 91 or 93 (i notice it runs better with 91) always. If you cant afford a few extra bucks every time you fill your car then this is the wrong car for you.
z-maro
03-30-2012, 02:55 PM
From the owners manual it sounds like running low or mid grade is just fine? :engarde: It certainly doesn't sound like it would cause damage to the engine?
http://shbox.com/pdf/2001firebird.pdf
http://i39.tinypic.com/dcpdx.png
Not saying you should run regular, but it shouldn't cause any damage?
projectX
03-30-2012, 03:08 PM
Just go premium unless your broke - then do reg but stay out of it if you do.
S8ER95Z
03-30-2012, 03:45 PM
It won't cause damage on a stock tune.
BadBirdie
03-30-2012, 03:47 PM
same here
x2
staleycornell
03-30-2012, 04:07 PM
Im scared to run anything through mine that isnt 93. I also put the TCW-3 oil in the tank..one ounce for every 5 gallons. For anyone who doesnt know, there is a whole thread about it on another site. Been doing it for a year now..
chasgiv3
03-30-2012, 04:29 PM
My motors only at a 8.9:1 ratio so I could easily run regular gas in it. Unfortunately I'm too worried about getting into boost so I stick with premium up to about 14PSI. After that 110 keeps me safe.
02WS6_Publix
03-30-2012, 06:39 PM
Wow thanks for the response from everyone I will be sure to start running 93 ASAP, I feel stupid for not thinking about it before i filled up but then again it was the first time I filled up the new car. So considering that its a 2001 T/A WS6 totally stock do you think it will hurt it any? I wish I could empty it out and just go put 93 in it right now. lol
S8ER95Z
03-30-2012, 06:46 PM
It won't hurt anything but performance (marginal) and gas mileage. I ran a 13.1 @ 108 bone stock with 89 in the tank.
staleycornell
03-30-2012, 06:52 PM
You could always run to AutoZone or something and buy some Octane Boost and pour it in there.
02WS6_Publix
03-30-2012, 06:59 PM
Now that we are on this topic.... The WS6 is a weeked toy / Hobby for me, If i'm on my way to autozone, what other small things do you all recommend that I could do with it sitting in the garage most of the time?
staleycornell
03-30-2012, 07:05 PM
Mine gets driven about once a month MAYBE. Unless it is sitting for long periods of time, you really dont need anything. Mine sat through a good bit of winter, even though we didnt have much of one this year. LOL. Only thing I needed was a battery tender to keep the battery warm because when it came time to crank up, it was a fail. But if you drive it on the weekends, you should be OK.
02WS6_Publix
03-30-2012, 07:12 PM
Awesome, Thanks for the advice. I live in Florida so I think that my battery should stay warm. haha
Im being a little over careful because I want to make sure I do all I can to take care of the car. I'm 19 years old and dont want to be the idiot kid who messes up his dream car. lol
staleycornell
03-30-2012, 07:20 PM
Oh yeah you dont need anything..lol. Im so anal about my car it is unreal. There has to be absolutely 0% chance of rain for me to get it out. Even 10% is too high! lol. Plus i took her in for a $275 detail job and she looks damn near perfect. They were able to take all scratches and swirl marks out. Its a black car so it made an absolute world of difference
02WS6_Publix
03-30-2012, 08:02 PM
Wow thats awesome, mine is Pewter... I still would love to get a great detail job like that..... I will have to search around and see what is near my town. And on that point of rain.... I totally agree with you 0%-6% is ok for me. LOL
BLK95-Z
03-30-2012, 08:17 PM
I havent pumped a gallon of premium in I dont know how long. My cars run fine
jbridwelltransam
03-30-2012, 08:53 PM
I'll test this premium thing. I'll calculate my mpg when this tank is up, it is 87. Then i'll fill back up with 91 and see if it makes a difference.
02WS6_Publix
03-30-2012, 09:19 PM
Yeah, I am going to do the same and see how the performance changes =D
99 ss
03-31-2012, 01:51 AM
I only use Bp gold witch is 91 oct in my region it use to be 92 oct man I want to try that v power in my car so bad I don't have a shell gas station in my area dam it
02WS6_Publix
03-31-2012, 11:22 AM
I think im going to go with shell here.
wav3form
03-31-2012, 12:21 PM
I only run 93 because that's the most common "premium" in my area. There's a place that has 92 but I don't like how it feels - I can't quite explain it but the car doesn't seem to like it.
Is 87 regular 89 midgrade and 91 premium just a California thing?
RPM WS6
03-31-2012, 07:38 PM
87 regular and 89 midgrade are nationwide as far as I know.
But premium can be 91, 92 and/or 93 octane depending on where you live. Some places used to sell 94 as a normal premium pump gas as well.
My thoughts, why buy a performance car, just to degrade the performance. If you don't have the money for premium gas you really shouldn't be driving a performance car.
versz
03-31-2012, 10:55 PM
^ this.. /thread
Unertl42
04-01-2012, 11:05 PM
I like to think of it this way,
It really only cost me ~$3 more to fill up with 93 than 87. I can afford an extra $3, especially since I'll get better gas mileage with the higher octane
02WS6_Publix
04-02-2012, 05:13 AM
Touche'!!!
silver04goat
04-02-2012, 09:27 AM
Agreed. I only run 93. I never see 91 available anyways at least not in jville
S8ER95Z
04-02-2012, 10:16 AM
Both of these... It's really not a big different to fill at most an extra 5 dollars which is easily lost if you put in the lower octane and get worse mileage.
LS1WS6dreamer
04-02-2012, 01:59 PM
+1. i tried to run 89 one time. Man did the gas gauge move quick. Also, just didn't feel right. If you can find someone with 91-93 with NO ethanol it helps too. The non ethanol gas is just so much better here. Not only with my car, but my truck as well. ATV's everything. It makes a difference.
wicked383lt1
04-02-2012, 02:51 PM
How about e85?
LS1WS6dreamer
04-02-2012, 03:16 PM
How about e85?
Don't even know what it is. lol
02WS6_Publix
04-02-2012, 06:50 PM
So what say you about Shell gas 93? thats what I think im going with from now on.
99 ss
04-02-2012, 11:52 PM
yea shell v power or bp gold is the best for our f-bodys i would use shell v power as well but i dont have one in desmoines ia i wish thay would put a shell here
02WS6_Publix
04-03-2012, 10:46 AM
Alright thanks for that. Now I just have to drive my WS6 enough to empty the tank so that I can fill her up with V Powered.
NC98Z
04-03-2012, 03:16 PM
Does it?? Or has you CPU pulled timing to make up for that cheap gas? Those knock sensors under your intake are there for a reason. In your case when you do descide to run 93 octane again you better pull the battery lead off for a couple of minutes so it can relearn its spark tables.
gocartone
04-03-2012, 05:00 PM
Worst case you would save a little over $100 every 10k miles using 87 vs 91, but that math only works if you are getting the same gas mileage with both. If your gas mileage drops 2mpg it would be CHEAPER to run the 91, which is why I have no idea why so many people are too dumb to realize that there is NO gain to running 87 over 91 on a car that's made for 91. You can't say it's too expensive, because more likely than not your going to see at least a 2mpg drop with the piss fuel, making it more expensive than 91. This has nothing to do with the power drop you will see which only makes it that much worse to run 87.
BLK95-Z
04-03-2012, 05:12 PM
Yes sir, perfect. That extra 3 horsepower you gain from better fuel makes me no difference sitting in traffic on the way to work, if Im going to the track its different.
Now if you built an expensive engine Id always run good fuel. My junk is stock
StuntmanMike
04-03-2012, 06:22 PM
Yeah, but what's your mileage? I ran a tank of 89 through my car once, and it ran fine, I couldn't feel any difference, however the gas guage moved alot quicker. I lost 3mpg, so even though I saved a lowsy .15/gal, it cost me more in the long run since I had to fill up a day earlier.
BLK95-Z
04-03-2012, 06:43 PM
Ive honestly never tested the milage with 93, Ill try it next tank and tell you guys what happens :drive:
WNTSOMZ
04-03-2012, 07:03 PM
93 oct here
SparkyJJO
04-03-2012, 07:29 PM
1) Open manual
2) Read about recommended fuel
3) Fill with recommended fuel
4) ...
5) Profit.
runtwrestlin
04-03-2012, 07:30 PM
How about e85?
I'm guessing you're being sarcastic, right?
Don't do E85 (85% ethanol). From everything I've read about it, it will be bad if the engine is not made to run on it.
LS-ONE_DAY
04-03-2012, 08:03 PM
Think of it this way...(using my location as an example)
Regular - $3.99
Medium - $4.10
Premium - $4.22
Say you fill up 10 gallons, thats 39.99 total using regular and 42.22 using premium. Does that $2.23 difference between the two really matter cost wise? No.
Stick with premium.
02WS6_Publix
04-04-2012, 12:10 AM
I totally agree that we should all run 93/Premium to keep our cars in the best posible condition and also to save when it comes to MPG.
Also think of it this way too. For every 1 mpg you lose (at say 20mpg average) you are losing about $2 per fill up. About the same as switching to regular gas over premium. I would imagine you would lose 2-3mpg, so now you're spending about $4 more to fill up with regular than you would premium.
Math: 20mpg x 10gal = 200 miles per fill up. 19mpg x 10gal = 190miles per fill up. Net loss of 10miles. 10miles / 20mpg = 1/2 gallon of gas. 1/2 gallon x ~$4 gal = $2
Firebirdmuscle
04-06-2012, 10:00 PM
93 all the way. Filled up this evening from 1/4 tank. $42.00 filled up all the way with 93.
UAE_Z28
04-08-2012, 01:38 PM
I fill her up with 95, is that considered as overkill ? the next option is 91 or 98
240sxls1
04-09-2012, 07:20 PM
one thing not mentioned as running lower grade gas you can have emission issues lower grade gas will produce more carbon which can clogg up your egr valve so u might want to check that because it will also reduce your gas mileage
perf0rmance
04-12-2012, 04:50 PM
You should always run the octane rating for which your car was tuned for i.e. stock tune = factory recommendation.
Short lesson:
Octane rating relates to resistivity to ignition. The higher the rating, the more heat is needed to ignite. This is especially useful with boosted applications.
Typical results:
Lower octane - pinging/pre-ignition
Higher octane - unburned fuel
Running too low of an octane can cause your fuel to pre-ignite before it should.
Running too high of an octane can leave unburned fuel in the chamber.
BIG_MIKE2005
04-12-2012, 05:11 PM
LOL, you guys are gonna cringe when I tell you this.....I run 87 in mine, LMFAO. And here is the kicker, no knock & no other issues. Been running this combo for 80k miles on 87 octane from a station that only sells 100% gas. Car never sees ethanol, when I did put gas in from a ethanol station I got knock. I used to spend the coin on 91 till everyone started dumpin 20% ethanol in it. When I switch to this 87 I run now I got throttle response back, MPG back, smoother idle & no loss in power. Trips to the track backed up my no loss of power with consistant ET's.
I'm not exactly sure why I dont have issue or if I even should have issues, I just know this gas works just fine for my NA car. Now if I was gonna be boosted or spraying i'd spring for a higher octane. but as of right now till my car gives me reason to spend more at the pump I'm gonna keep rockin 87.
perf0rmance
04-12-2012, 07:04 PM
Unless you can clearer record/track knock, the PCM may be pulling timing. It doesn't mean what you're doing doesn't work, but I'd say it's less than ideal if the factory calls for a different octane rating other than the one you are using.
NOTE: using octane booster does very little in actually raising octane
BIG_MIKE2005
04-13-2012, 07:07 AM
I have a Aeroforce scan gauge that monitors knock/coolant temp. It has been looked at and had basic edits done like rear O2 delete, skip shift delete, Air/EGR delete & so fourth. I believe the guy even took a couple degrees timing out cause when I had the edits done it was before the H/C/I swap & I was gonna hit it with a 100 dry shot.
Maybe that pulled timing is whats helping, who knows. I just know I only see slight knock if I'm in 5th & start goin up too steep of a hill without downshifting. But according to the scan gauge its minimal knock even then.
216StealthSS
04-13-2012, 07:25 AM
yes sir! owned the car 3 years and never put nothing else but 93 v-power! i get a avg of 19MPG.
mandatws6
04-13-2012, 09:40 AM
Was thinking about if it matter. Thanks for info
RebelExtrm02
04-14-2012, 09:44 AM
I'm fortunate enough to live in a city that has a gas station with guranteed no ethanol 94 and I pay whatever they want for it. It's just not worth the $4 difference over a whole tank to get the crappy stuff, especially since my car is modified and tuned to take more advantage of higher octane fuel.
arob987
04-14-2012, 10:18 AM
93 here
Cstone812
04-14-2012, 10:22 AM
Only way I would put regular in it is if my car was completely stock and my daily driver...if its your weekend car or is modded out the ass PUT 93 IN IT otherwise why did you even buy the car?
/thread
BillyMitheRxguy
04-15-2012, 07:29 PM
premium or race fuel is the best
