Sadden
03-30-2012, 11:18 AM
Hello everyone. Im looking at spraying my GXP after a couple more mods , and have a couple questions.
Im only looking at a 75 shot , 100 tops.
For this reason id like to use a zex blackout kit. I know some of you guys dont like this because down the road you guys start to outflow it.
But im not plannning on spraying any more than that.
Im interested in that kit because it looks to be a very clean install, but also because it looks like i wont have any noids to try and hide in my engine bay (sorry i just dont like the look of noids hanging off of everything , with the exception of some of nitrous outlets builds).
Id like to use nano in order to keep the n2o as consistant as possible for tuning reasons.
Yes i would be adding a TPS switch.
Basically id like to do 2x 10lb bottles , and a nano capable of pushing both.
So
A) Is there a nano that can push 2x 10lb bottles?
B) Is nano even compatable with the zex valve assembly?
C) Im 1 heat range cooler than stock atm , how many more should i drop , and are the ngk iridium plugs suitable for use with n20?
d) Is there a bracket that will support both n2o bottles and the nano for a cleaner look?
Thank you all for your time.
So
