maddogmike_06
03-30-2012, 09:39 PM
ok my car.....2000 ws6 107000 has cam unknown size and bolt ons stock 241 heads stock rockers and trickflow 7.4 pushrods....
my problem...i have had car about 4 months and always a bad chatter not the sewing mechine, ive checked pushrod length with adjustable and they are the right size with about .060 preload......so i started pulling apart to replace the lifters with ls7 and saw that the pushrods (ALL OF THEM) both sides are rubbing the head bad while running and not the pushrod hole its rubbing at the top right under the valvecover gasket surface......i say while running because right now they all have about 1/8'' gap between PR and head....i also saw that on the driver side only the rockers are hitting the covers........not sure what to do now could i just grind a spot out with a die grinder or is there something else wrong??????
