Carbureted LSX forum - Carb'd LS build for dirt track (lots of pics)
driver56
03-31-2012, 01:30 AM
Thought I'd share some pics and story of my engine build. Short story: Built last year as a 402, this engine was ran for a few races in a USMTS style modified and one race in my dirt late model. Had some oil control issues that resulted in needing a fresh block (got the mains a little hot). Since the motor was apart I decided to upgrade a few things like a bigger bore, some cyl. head work, better intake, better carb, etc. So here it is, all 408ci of it, 13.5:1 compression, solid roller, distributor conversion. I have to admit I'm pretty stoked about it and can't wait to get it in the car. Bring on the pics!
Cutting the deck a little:
http://i186.photobucket.com/albums/x27/stephens56/444-1.jpg
Crank and cam and timing components in:
http://i186.photobucket.com/albums/x27/stephens56/459-1.jpg
Full custom RaceTec pistons with dome to match my heads combustion chamber:
http://i186.photobucket.com/albums/x27/stephens56/462-1.jpg
Rod assemblies ready to go:
http://i186.photobucket.com/albums/x27/stephens56/463-1.jpg
All in:
http://i186.photobucket.com/albums/x27/stephens56/465-1.jpg
Oh yeah! :
http://i186.photobucket.com/albums/x27/stephens56/466-1.jpg
Bottom end all buttoned up:
http://i186.photobucket.com/albums/x27/stephens56/468-1.jpg
The start of a custom 50* intake valve job:
http://i186.photobucket.com/albums/x27/stephens56/375-1.jpg
Another shot of the intake cut:
http://i186.photobucket.com/albums/x27/stephens56/379-1.jpg
Heads ready to go together:
http://i186.photobucket.com/albums/x27/stephens56/432-1.jpg
Measuring valve spring height:
http://i186.photobucket.com/albums/x27/stephens56/428-1.jpg
Heads assembled and ready to install:
http://i186.photobucket.com/albums/x27/stephens56/437-1.jpg
The icing on top:
http://i186.photobucket.com/albums/x27/stephens56/445-1.jpg
Heads and lifter valley cover on:
http://i186.photobucket.com/albums/x27/stephens56/469-1.jpg
A quick shot of my stainless cross-over set up:
http://i186.photobucket.com/albums/x27/stephens56/482-1.jpg
All dressed out and ready to fight:
http://i186.photobucket.com/albums/x27/stephens56/478-1.jpg
On the run stand with the headers that fit my race car:
http://i186.photobucket.com/albums/x27/stephens56/490-1.jpg
For those of you not familiar with circle track stuff this is a shot of the magnesium bellhousing with its rear mounted starter. The flywheel is very small (6 1/4" in diameter) and only weighs a couple of pounds, makes for wicked throttle response. The flywheel also has a cogged belt drive on it to run a belt driven power steering/fuel pump that mounts on the bracket on the upper left of the bell.
http://i186.photobucket.com/albums/x27/stephens56/485-1.jpg
So that's it, I hate to take a WAG at a horsepower number, but it should be enough for a 2200lb car.
Enjoy the pics!
02sleeperz28
03-31-2012, 01:40 AM
Nice pics, in for the rest of the build. What kind of car is this going in? What trans?
driver56
03-31-2012, 01:52 AM
2008 Rayburn with a BERT 2-speed trans. This pic was before going to a special "topless" race.
http://i186.photobucket.com/albums/x27/stephens56/2011%20Late%20Model/042.jpg
NemeSS
03-31-2012, 01:54 AM
Awesome!
Pop N Wood
03-31-2012, 08:14 AM
Thanks for the pics. Better than watching powerblock.
GNCLONE
03-31-2012, 07:56 PM
Is coil on plug (with MSD box) not allowed?
3pedals
03-31-2012, 09:37 PM
looks good!
driver56
03-31-2012, 11:32 PM
Engine rules for this class of car are pretty loose but typically say "must be distributor fired" or "only one ignition coil allowed". Most common engine combination is a 410-430ci (a lot are spread bore spacing blocks) with any head allowed as long as it's 2 valve per cylinder and one spark plug per cylinder, 750-850hp is what the good ones are making and cost upwards of $40K.
Zmg00camaross
03-31-2012, 11:56 PM
So how much HP you think? You think you will be competetive power wise?
driver56
04-01-2012, 10:31 PM
I really hate to guess, but it has enough cam, compression and cylinder head to make around 650 at the crank ( I think). A wheel hp number would be hard to guess because these cars' drivelines are so different from a street car. Will it be enough for the series I'm going to run with? On a small track, maybe. On a bigger half-mile or a fast 3/8 mile track, I probably don't stand a chance at the top 5.
Denny28
04-05-2012, 06:53 PM
Im building one for a ump modified very similar to your combo, are you on gas or alcohol? I am also curious about your oiling problems, I currently have a kevko circle track pan, afco deck mount cooler, cvr remote filter boss with a melling pump.
driver56
04-06-2012, 10:03 AM
I believe it was a combination of things: main clearances were too tight, a Melling 10296 pump (ran the pan dry), thin rings, and a rear main seal leak that didn't leak until high RPMs. So the new combination has .0035 clearance at the mains, a Melling 10295 pump, a custom 1/16, 1/16, 3/16 ring set, and I made an alignment sleeve for the rear cover so the seal has a perfect fit. If I had to do it again I'd run oil restricted pushrods too, but I was already invested in a nice set of Mantons this time. I also have the Kevko pan but with a FSR oil cooler I bought from Mullins, it was designed for a wet sump applicaton. If you run a stock block you shouldn't have any oil drain back issues, but if you get a LSX block you'll have to modify the valley area somehow to add some return holes because the valley will hold a LOT of oil. I'm on gas with this engine. I was on a half-mile turning 7500, that's why I think it ran the pan dry with the high volume pump. I've since re-routed the oil filter adapter and the cooler lines, made them a little longer to add some capacity to the system. It's got 9 quarts total in it now.
driver56
06-29-2012, 06:40 PM
btt.....
3pedals
06-29-2012, 08:17 PM
Any plans to put it on an engine dyno? I think it should be well over 700 for sure if the heads are done right, and the cam is right.......
driver56
06-29-2012, 11:48 PM
No plans at all for it, I have it listed for sale here and on several sites, the car too. I want to get something I can race more often and closer to home. I'll probably go back to a stock car class, there's some races around here I've always wanted to run in.
21rev_z28
07-01-2012, 09:40 PM
Where do you run at? Ive got a grt and im wanting to do a ls motor really bad but my local track doesn't allow them yet.
driver56
07-01-2012, 10:13 PM
I'm in eastern Oklahoma, not too many places to run a LM around here. I've thought about getting a modified, but they cost just as much to run as the LM and the engine rules are tailored to the Brodix spec head engines. Why won't your track allow the 'LS'?
21rev_z28
07-02-2012, 12:14 AM
The track promoter doesn't accept change... Theyre are probly over 100 sport mods around the area (central nebraska) but he won't get the class at our track yet. I'm thinking about getting a ls for a few special shows that come through though. How do you like running with one? Is there alot of guys running them around that area?
driver56
07-02-2012, 10:20 PM
No sportmods local here either, even though one of the best builders in the country (Big Chief chassis) lives just up the road from here. I like the power of the 'LS', I was able to run down the front straight with 2-time IMCA Natl. Champ Justin Wells at the start of a heat race, but he daylighted me through turn 1 & 2. I got some chassis work to do.......
JUSTINSWS6
07-02-2012, 10:23 PM
Did you build it or who did?
ZONES89RS
07-03-2012, 01:04 AM
I think it is BS the rednecks will not allow the LS with stock heads and a MSD ignition. It is cheaper than going SBC, last longer and the SB Chevy is getting harder to find in decent shape. Not to mention they won't hold rpm without arp bolts and supporting mods.
Guess they will have no choice eventually. 5.3 are everywhere and highly capable. Not to mention the 4.8 will spin 7800 with no problem with a cam and springs.
Just haters.
driver56
07-03-2012, 11:17 PM
Yep, I built it after-hours in the shop.
orange88ls1s-dime
07-14-2012, 07:37 AM
how much you asking for the engine without distributor drive setup?
Beaudacious
driver56
07-15-2012, 12:56 AM
Beaudacious
It kinda has to have it, there's no reluctor wheel on the crank and all the sensor holes are plugged.
orange88ls1s-dime
07-15-2012, 01:03 PM
Id put a full MSD crank trigger setup with belt driven distributor on. So how much?
Just like my buddy's car
Beaudacious
KnightRyder25
12-30-2012, 02:44 AM
I'm in the process of putting an LS motor together for a UMP modified. I know I have to run a distributor but I'm not sure which way to go. The belt driven? Or buy the front cover and run the ford distributor? Neither way is cheap. Which is better?
wildcamaro
12-30-2012, 09:03 AM
Pretty gnarly looking, dirt racing is fun bc there ain't no lifting of the gas lol
orange88ls1s-dime
12-30-2012, 09:12 AM
I would go belt drive dist ,way better setup
booboo37
12-31-2012, 03:32 PM
Why is it way better ? Also whats it cost ? Whats needed ?
orange88ls1s-dime
12-31-2012, 07:30 PM
IWhy is it way better ? Also whats it cost ? Whats needed ?
I've seen a couple instances where the Spud on the cam came free and did some damage in the front dist app . Plus the belt drive setup works well in high rpm apps and under lots of up and down abuse.
Doug G
12-31-2012, 09:05 PM
Thats the steam line I'm getting ready to do....just need to pick up some 1/4" tubing.
SKULL
01-01-2013, 11:03 AM
you should port match the intake to heads. im sure that is worth a little bit. i saw someone who did a port match for his vic jr to his heads and it was RETARDED how off it was
super bad ass btw
gregsss
01-04-2013, 11:07 AM
13:1 compression on a ls, wow. I bet you want have any problem keeping up with bigger SBC engines.
Mell00
01-05-2013, 10:25 PM
Awsome to see an LS in modified. Hope it takes off in dirt track. What kind of valve train are you running?
Cobra4B
01-11-2013, 02:29 PM
Nice work on the steam pipes. Curious... I read that it's best to run it to the top of the cold side of the radiator so all the steam goes somewhere. Running it to the top of the water pump can allow any steam to collect in the pipe... any experience with this?
I ask because I'm about to put a carb'd LSX in my father's Panoz and am having a new dual pass radiator built with a provision for the steam pipe vs. just putting it to the water pump as others have.
Doug G
01-11-2013, 06:26 PM
Some say there is no steam, its just a vent line to allow the coolant to fill all the ports so no air is trapped.
As for where the line gets hooked...I think on the suction side of the pump is just fine.
Cobra4B
01-11-2013, 10:29 PM
Interesting... always heard them referred to as steam pipes used to get any air created out of the heads from hot spots when racing. If there is no steam then plumbing to the water pump would be fine, but if that were the case then there'd be no reason to have the older style LS1 pipe that uses all four ports.
driver56
01-16-2013, 05:45 PM
We also did another LS for a dirt car, a Super Stock is what we call them around here, a 3000lb 2nd-gen Camaro. It was a 427 in a LSX block with a set of worked over iron heads, solid roller valvetrain, Super Victor, distributor cover with a DUI HEI in it. We plugged the vent ports in the corners of the heads, ran no water crossover what-so-ever, had ZERO issues. I think the whole steam thing is over rated.
I think for dirt track racing the distributor conversion cover is better because everything is contained inside, versus a belt drive where everything is exposed to potential rocks and debris from the track. Drag racing would be a different story though.
My complete engine is for sale, BTW.
