Cadillac CTS-V - diff bushing
furbe
03-31-2012, 01:55 AM
Anyone replaced the diff bushing on a V1? Any advice on replacement? Mine is hammered
Thanks
Onefast V
03-31-2012, 03:16 AM
Creative steel bushing. Period.
01_SuperSlow
03-31-2012, 09:47 AM
Creative steel here as well.
chitown21y
03-31-2012, 10:58 AM
https://creative-steel.com/store/index.php?l=product_detail&p=31
https://creative-steel.com/store/index.php?l=product_detail&p=48
FuzzyLog1c
03-31-2012, 11:15 AM
Would one of you guys be willing to write a quick summary of any drive or shifting quality changes that you noticed after installing the Creative Steel differential bushings?
dangrus
04-01-2012, 08:35 AM
After replcing the rear diff bushing, the jerk that you would feel after shifting is gone. I replaced motor mounts on Saturday and the bushing on Sunday and only drove about 40 miles in between. I drove it enough to know that there was still slack in the drive line that made it hard to shift smoothly. The stock bushing didn't look worn out but it made a difference. I used the CS tool and it worked pretty good, you are not getting it out with out a special tool.
johnny2343
04-01-2012, 09:14 AM
It can be done without the tool , but it is such a pita
6 SPEED Z
04-02-2012, 07:09 AM
CS bushing, watch the exhaust bolts at the cats, mine snapped on the left side (Might want to try a little heat on them first, although mine were stock and had never been off since new, def use some good lube if you have no heat). Car tracks in a straight line now, always wanted to pitch right. And NO CLUNK... lol.
Mike
SSmokd U
04-02-2012, 07:29 AM
I replaced mine with a CS about a year ago but somehow the three diff bolts did not tighten all the way. I drove it until this past weekend thinking I had a bad driveshaft. Got under it to swap the shaft & put in CS motor mounts, realized this & just torqued the hell out of those bolts. Now with that & the mounts done this car feels totally different. More planted. I can shift with no worries.
Just a recommendation: get the mount bundle from CS. Motor mounts, trans mount, diff bushing & diff block. You won't be sorry.
FuzzyLog1c
04-02-2012, 09:13 AM
I hear that the CS transmission mount causes a ton of noise/vibration issues. I wonder if those issues could be correlated to CTS-Vs equipped with short shifters. Was planning on doing CS differential mounts, UMI motor mounts, and leaving the transmission mount alone unless there are shifting/driving advantages to be had due to poor alignment caused by the OEM mount.
Mine was shot to hell, you could feel / hear the diff rocking while shifting. I took the easy route though and paid a shop to replace the bushing and add the diff block. It made a huge improvement. It felt so much more planted taking off from a dead stop and I was able to get a tiny chirp out of 4th gear.
