Generation IV External Engine - Who makes a cable driven throttle body for ls3????
02 Camaro
03-31-2012, 10:31 AM
Im building a 403ci ls2 and using l92 heads with a port matched l76 intake to go into my 02 z28 so im looking for a cable driven throttle body for the ls3. thanks
bww3588
03-31-2012, 11:07 AM
I just bought a BBK 92 MM TB from S&K speed. less than 300 shipped to my door brand new.
Also, FAST makes one and a few other companies. lots of options. just make sure it is a 4 bolt TB for the LS3/L76 intake.
1nasty86
03-31-2012, 11:41 AM
buy a nick williams 92mm.... hands down best throttle body company out there
http://www.ws6project.com/user_stor/catalog/98-02-ls1-nick-williams-92mm-throttle-body/
93Z2871805
03-31-2012, 11:49 AM
Professional Products makes a 101mm and a 96mm, they are $230 and $220.
02 Camaro
03-31-2012, 04:50 PM
I saw this one but would it fit on a l76 manifold?
02 Camaro
03-31-2012, 04:51 PM
Is there a size limit on throttle bodies? Its a stock l76 intake so would a 101mm even work?
gectek
03-31-2012, 08:28 PM
You can use a 102mm TB, but honestly there may be some issues with smaller CID with it. Sometimes bigger is not always better, and it takes a bit of porting on the TB area to make sure it will fit.
That NW 92 is one of the best out there and WS6 Store is a good place to get them from.
gectek
03-31-2012, 08:53 PM
Do not forget you will also need a cable bracket since the ls3 intake has no provisions for it. WS6 store sells those as well.
SweetS10V8
04-01-2012, 08:16 PM
Ive used FAST 92mm throttle bodies on all my LS3 cable intakes
02 Camaro
04-02-2012, 12:41 AM
Can you send me a link for this ... im having trouble finding it
gectek
04-02-2012, 12:47 AM
He does not have it listed, but does offer it. I would give them a call in the morning, they can get you price and everything.
95wannabe
04-02-2012, 11:04 AM
What are you doing for map sensor? LS1 or 3?
Which is the best way to go or does it matter as long as your tuner is aware?
02 Camaro
04-02-2012, 08:19 PM
I believe Katech sells an adapter for the ls1 map sensor to use on the ls3 intake... Are you doing a similar build or just curious?
gectek
04-02-2012, 08:35 PM
You may have to change a few of the map readings for the LS3 to work correctly. WS6 store sells the adapter as well. He has quite a few things for almost any f body with any type of LS swap in it.
95wannabe
04-03-2012, 05:01 AM
same swap, except stock LQ4 shortblock
Oh4GTO
04-04-2012, 12:33 AM
You need an extension harness for the MAP. I got the cable bracket from Speed Inc. and Im using a 90mm Nick Williams. No reason to go bigger because the LS3 manifold opening is 90mm.
uneek1976
04-04-2012, 09:23 AM
Do you have a part number for the bracket?
gectek
04-05-2012, 08:15 PM
Here is the bracket
http://www.ws6project.com/user_stor/catalog/product_info.php?products_id=4692
bww3588
04-05-2012, 09:44 PM
It says it fits any NW TB.does that mean it only fits NW TB's or any TB?
gectek
04-05-2012, 10:24 PM
As long as there is a bolt hole in the back of it for the bracket to attach to then you are ok.
Oh4GTO
04-06-2012, 11:43 PM
Sorry forgot about this thread.
http://www.speedinc.com/cont.cfm?cid=C0000823
