Drag Racing Results - I believe I should have been faster...
its turbo time
03-31-2012, 12:57 PM
So my setup is basically all boltons, 3200 circle d stall, comp cam 224, tune and my best time last night was a:
13.0 @ 107
2.0 60'
Shouldn't at least my trap speeds be faster with my setup?
No one was hooking last night and my DRs are a little dry rotted so I had a hell of a time getting out of the hole.
its turbo time
03-31-2012, 12:58 PM
Could my tune be off?
GtoSpd
03-31-2012, 01:28 PM
Whats the DA and/or elevation where you are?
Even on a 2.0 60', you should be running much faster than that. You ought to be able to run high 11s pretty easily with a 1.7-1.8 60'.
Could be the tune, hard to say. Who tuned it for you?
its turbo time
03-31-2012, 04:19 PM
That's exactly what I want lol! High elevens with a reasonable launch.
The guys name is Omer, I can't think of his company name. Everyone around here said he's the guy to go to.
Other reasons I think the tune is off is that. He purposely left it fat cuz he saw that I have a bottle. And the car has idle surge problems and will sometimes die. I figured it would relearn to idle and be better, but not!
evilz99
03-31-2012, 05:19 PM
Yeah sounds like a poop tune. You should be way faster.
GtoSpd
03-31-2012, 05:50 PM
I totally understand his reason for tuning it rich, but I dont get him not addressing the idle issue. I would search for a better tune asap. There's a lot left in her, like well over a full second.
1999transamls1
03-31-2012, 07:46 PM
Contact joe at Pbj, he's located off Hampton, he did my tune and did a great job. You can google his number
its turbo time
04-01-2012, 01:40 AM
Thanks, If i can't get thing squared away with omer I'll give him a call. I am hoping that after dropping four hundred bucks with him I won't be charged any more for him to fix it
1999transamls1
04-01-2012, 09:21 AM
And also, nobody's peferct either, it's possible he did forget something. It's really not a big deal if he's willing to fix it.
Killer5.3
04-02-2012, 06:15 AM
Tuning it rich is not neccessary just because you have nitrous. If it is a wet kit the fuel solenoid will take care of the extra fuel it needs. That's what it is for. The only thing he should have really been concerned with is taking timing out for the kit. If you were running say 150 shot and he put in the nitrous tune it would probably be around 22 degrees total timing and you would lose about a .10 or so versus n/a or motor tune. You should find a new tuner asap as he doesn't have a clue it sounds like. That car isn't even trapping what a bolt on car usually traps. You are missing at least 6-7 mph.
thunderstruck507
04-02-2012, 11:06 AM
Where did you run? Was it hot and humid?
The car should have a good bit in it, but if it is full weight and guessing the type of DA you probably had, I wouldn't expect quite as much as everyone says.
For what it's worth my car trapped 109-110mph with a 230/224 cam and stock heads. Now it's 111-almost 112 with 230/238 cam and lightly worked 799 heads. Weighs 3750 or so with me in it. You can probably squeeze out a couple more MPH than me due to aero.
GtoSpd
04-03-2012, 12:25 PM
I think you are confusing my car with the OP's car. Judging by what my car is running for the mods, I'd say my tuner knows exactly what he is doing.
I alrea know about pulling timing for nitrous. But you go ahead and spray a lean car, let me know how that works out for you.
its turbo time
04-03-2012, 04:41 PM
Well it dynoed 361 hp/373 tq like two weeks before I ran it and no, it was not hot or humid. It was in the 60 degrees at gateway in stl.
its turbo time
04-03-2012, 04:43 PM
Are you on a stock stall? If so, nice times!
GtoSpd
04-03-2012, 04:58 PM
Yes sir! Thanks man!
transamtom
04-03-2012, 05:11 PM
13.0 @ 107
2.0 60'
I think you need a new tuner.
No Stall, Cam or Gears, my car went 12.887 at 108.49 on a 2.031 60ft with just Free mods LT's and LS6 intake with a Frost mail order tune.
BTW it has 126,000 miles on it.
its turbo time
04-03-2012, 05:17 PM
I'm beginning to think you're right. This guy is named Omer Phelps and claims to be a master tuner for Ls1's. Best part is, I emailed him about my track experience and he said he did what he could, and it must be the tranny or the fact that my car has 130k on it when the tranny was redone 20k ago and the motor only has about 70k on it cuz it was warranteed. Hasn't emailed me back since Sunday.
its turbo time
04-03-2012, 05:18 PM
I could reflash my PCM through pcmforless for $50...
GtoSpd
04-03-2012, 06:39 PM
PCMforless "Alvin" knows there stuff....
Tan327
04-03-2012, 07:02 PM
There is good tuner in STL named Shane(not sure if he wants his last name given out), he is also on this site named 04BlackGMC ..link to his profile below, shoot him a PM.
http://ls1tech.com/forums/member.php?u=15841
its turbo time
04-03-2012, 07:52 PM
Thanks Tan327, I sent him a PM
04BlackGmc
04-04-2012, 09:48 PM
something is for sure off.
I tuned a Pontiac G8 that was at the track saturday
mods being axleback mufflers CAI and tune and it was running 13.2 @106-108
its turbo time
04-05-2012, 10:12 AM
Can't wait to get her straightened out! Nice numbers for that basically stock G8!
its turbo time
05-22-2012, 03:59 PM
An update on this: 04BlackGMC retuned her and she runs totally different.
The plan is to run it Friday and see what it traps. It's not gonna hook so I'm not worried about et
its turbo time
08-18-2012, 09:28 PM
Update to this: took it to the track after the retune, some suspension mods and fixed a big vaccuum leak and ran a 12.8 @ 108 1.9 60'
So the suspension mods paid off a little (adj torque arm, panhard bar), but still no more trap speed. It was prolly 80 degrees that night.
Went to the track again after getting new DRs and putting in an offroad Y after noticing my cats were crushed and ran a 12.6 @ 109 with a 1.8 60'. It was about 60 degrees when I ran.
So basically I still haven't found why my car is still not at it's potential.
Tuner thinks my stall is too small and I need to put my car on a diet. Not sure what to think really. Car seems faster after doing all this but obviously it's not.
