Drag Racing Results - Finally got a little traction!
Golf&GM
03-31-2012, 02:07 PM
Ever since I installed my SS4000 I haven't had any luck hooking with my Nittos. So I ponyed up the coin for some ET Streets and FINALLY got some traction! I ran a 7.8 with a 1.7 60'.
It could've been a lot better, I still had to feather it out of the hole. I was in a rush to get to the track and forgot my tire pressure guage :bang:. I thought I was running 30psi, which is what I asked the shop to put in them when I got them mounted. I checked them when I got home, turns out they were pumped up to 42psi :eek2: If I lower the pressure down to the low 20s I think I could knock off a low 1.6 or even a high 1.5.
Here's the vid of my best pass
http://youtu.be/UjATpJY16Yo?hd=1
projectX
03-31-2012, 02:18 PM
Nice video man -MT ET Streets are where it's at for traction IMO
GtoSpd
03-31-2012, 02:44 PM
Nice work man! Car is leaving pretty hard. I def think you could rock out a low 1.6 with the pressure dropped.
Golf&GM
03-31-2012, 07:09 PM
Thanks guys, once I get the launch figured out i've got a 100 shot waiting. Hopefully those little 255s can take it.
6SSPEED
03-31-2012, 07:54 PM
I highly doubt the 255s will hold on a 100shot out of the hole but with good track prep and low psi they might bite.
senicalj4579
03-31-2012, 08:01 PM
Hey good job. At first I was having traction issues after my stall also. Would you believe it was because my motor and trans mounts were toast?
MT drs are great thats what im running now but if you really wanna get a good tire for the track get some hoosiers. I will be picking up another pair for track only.
Anyway great vid and good job!
senicalj4579
03-31-2012, 08:04 PM
Oh and just wanna add that all my 11sec passes were with 25-30psi in the mt drs. Didnt seem to spin so I didnt change it.
Golf&GM
04-01-2012, 09:18 AM
How did you launch it on the MT's and do you remember your 1/8 mile time? At the psi I was running it hooked best when I brake stalled it up to about 3k and then eased off the brake and into the throttle. With the lower PSI could you flash it?
senicalj4579
04-01-2012, 09:25 AM
I usually just give it a little to take the slack out. Probably 1000 rpm then put the hammer down wot.
My thread is here with all the info.http://www.ls1tech.com/forums/11-second-club/1473990-11-918-minor-boltons-ss3600-weight-reduction-vid-inside.html
Im adding 100lbs back to the car soon. But ill be doing heads and cam to so ill trade 100lbs in exchange for 100rwh :D
Golf&GM
04-01-2012, 10:37 AM
I'd say it would be worth it, your nose might come up a good bit more though. That was a great run, looks like on your 11.918 run you were 7.5 in the 1/8. I'd love to be able to get down that low. I looked up the DA and was at 1325' when I made my pass, hopefully we'll get some better and and I and I'll dip down close to that.
1Bad97WS-6
04-01-2012, 04:32 PM
Nice pass. What track was you running at. I'm gonna go to motor mile when I come down this summer to visit family. Hopefully by then I will have everything done in my Sig..
LS1rob00
04-01-2012, 06:42 PM
Nice pass. That 2V treed you hard! Haha.
I would definitely drop the pressure and see what it does for you.
Golf&GM
04-02-2012, 02:19 PM
It was at Natural Bridge. I'm probably going to Shelor next time, the track prep is usually better down there.
Haha, I gave him the hit to try to make it an interesting race. I didn't give him enough time because I still came around him and beat him by almost half a second :punch:
1Bad97WS-6
04-02-2012, 04:02 PM
Ok cool but Natural bridge has a lower DA then motor mile. I'll let you know when I'm down that way..
