Drag Racing Tech - Charging issue after battery relocate
SS#8788
03-31-2012, 06:27 PM
I did a battery relocate to the spare tire compartment. I took the factory connections and hooked them up to a distribution block with a 1G going back to the battery. I ran a 2G from the alternator to the battery. I have a 1G ground at the battery. I also did a 25% underdrive harmonic balancer and a 145A alternator. It holds just above what looks to be 12V (I'm just going off my dash). Any advice is appreciated. Thanks
Doug G
03-31-2012, 06:30 PM
See if it shows charging if you raise the RPM's up some.... the under-drive pully may be turning the alternator too slow.
SS#8788
03-31-2012, 07:35 PM
I'll take it for a drive tomorrow and pay attention to that. I was thinking the underdrive pulley may have something to do with it, so I bought the bigger alternator thinking it would make up for it. Is my thought process completely off track?
Big Al
03-31-2012, 09:06 PM
Sort of, but not that bad:) Just drive it and see where the voltage goes. Did you put a disconnect switch in the positive lead? Is this a car that will go to the track?
Al 95 Z28
SS#8788
03-31-2012, 09:37 PM
It will go to the track but I do not have the disconnect wired yet. Right now I'm trying to get it ready for a 1k mile drive from OK to MI.
01ssreda4
04-01-2012, 02:08 AM
Higher powered/amp alts usually put out less power at idle then stockers but more power as the rpms go up. I also would not be trusting the stock gauge for an accurate V measurement. Get a digital multimeter and tell us your exact voltage during a cold crank up and a warm idle.
SS#8788
04-01-2012, 05:30 PM
Ok thanks
SS#8788
04-02-2012, 09:33 AM
Got a multimeter and tested at the battery. ~14.4 at start and ~14.1 at idle. Driving at 2k rpms it's steady at 14.2 and my stock gauge is showing just under 13. So I guess the gauge is just off a bit. Thanks for the help
