Missing 4 cylinders help !!!
Old 03-31-2012, 10:20 PM
jarheadtex's Avatar
Default Missing 4 cylinders help !!!
I was just cruising yesterday and my car started missing. I have replaced plugs and wires and visually watched each coil fire. After running the car i can touch the back 2 headers on each side. The front 2 are hot on each side. So.....the back 2 cylinders on each side are dead. Any ideas?
Old 04-01-2012, 12:53 AM
jarheadtex's Avatar
So its cylinder 5678 no ideas?
Old 04-01-2012, 10:11 AM
ds98formula's Avatar
Have access to a fuel pressure tester? I would start there. That is a very weird problem.
Old 04-01-2012, 10:38 AM
outkast6991's Avatar
I'll bet you money it's a broken spring. Same thing happened to me. It was an exhaust spring on #6 which slowed the crank down enough to kill the back four cylinders
Old 04-01-2012, 09:25 PM
jarheadtex's Avatar
ok...I dont think its 4 cylinders. When I take off it will stumble then seems to surge into the power...but still missing. I have replaced plugs, wires, fuel filter, fuel pressure is good. Today we unplugged each injector and there was a change with each. As much as I hate to. I may take it to a shop. I can smell gas while it idling. It can damage the engine driving this way right?
Old 04-01-2012, 10:28 PM
please pull the valve covers before driving the car again. it only takes 20 min and could save you alot of cash. don't drive or start the car again until you pull the valve covers
Old 04-01-2012, 10:33 PM
jarheadtex's Avatar
Man.......you were dead on! Broken valve sprin on #6
Old 04-01-2012, 10:40 PM
Unertl42's Avatar
glad you found the issue, and save a TON of $
Old 04-01-2012, 11:02 PM
jarheadtex's Avatar
Well I am going to hope I saved money...I drove a good 40 miles like that.
Old 04-01-2012, 11:15 PM
jarheadtex's Avatar
I rotated the engine by hand and the valve returned to its up position. I hope there was no damage. I'm going to throw heads and springs on it and hope for the best
Old 04-02-2012, 12:07 AM
Glad you found it. Pull the valve up and hold it against the seat while spinning it in your fingers. That should give you an idea if it got bent
Old 04-02-2012, 12:25 AM
jarheadtex's Avatar
thanks..will do
Old 04-02-2012, 12:40 AM
No problem. What springs are you running?
Old 04-02-2012, 08:41 AM
jarheadtex's Avatar
Comp, beehive
