1969 oem fuel line to an lines
Old 04-01-2012, 10:44 AM
kirk69nova's Avatar
Default 1969 oem fuel line to an lines
I recently bought a stock 3/8" fuel line for my 1969 Nova, then I decided to do a LS swap. I don't want to eat the cost of the line if I don't have to. Is there an adapter that will allow me to use this original style fuel line, which use a typical worm gear hose clamp, and AN style lines?
Kirk
Old 04-01-2012, 10:53 AM
TomM's Avatar
Yes, it's a compression fitting on one end, and -AN inverted flare, or female on the other end, depending on how you want to go.....Jeg's or Summit carry them.
T,
Old 04-01-2012, 11:10 AM
kirk69nova's Avatar
Thanks Tom. Is this it? If so, I'd have to cut the oem line, put a nut on it, and then reflare it...right?
http://www.summitracing.com/parts/EAR-961947ERL/
Old 04-01-2012, 11:40 AM
99VetteFRC's Avatar
I got this from my local speed shop and it is 3/8 to female -6AN. I also have 3/8 to male -6AN I just don't have a pic of the male one. I used to adapt braided line to fuel rail.
Attached Thumbnails 1969 oem fuel line to an lines-dscn1177.jpg   1969 oem fuel line to an lines-dscn1063.jpg
Old 04-01-2012, 07:07 PM
TomM's Avatar
No, it is the one 99vette posted. Cut off the 3/8 hard line, clean the inside end a little, slide the fitting on and tighten it, the brass compression ring tightens down around the tubing. Then just just carry on with -AN from there....
T,
Old 04-02-2012, 05:33 AM
Pop N Wood's Avatar
I run AN compression fittings on the hard lines of my carb'd swap. The only warning is most brands are only rated to something like 50 psi. I would have no issues running them with FI pressures, but just so you know.
Old 04-02-2012, 06:08 AM
99VetteFRC's Avatar
And it's way cheaper than braided steel.
Old 04-02-2012, 08:56 AM
MikeFSKSpeed's Avatar
I have those fittings in stock from XRP, from hardline to either male or female 6AN
Old 04-02-2012, 09:28 AM
kirk69nova's Avatar
Thanks Mike, I'll add that to the list I have for you!
Old 04-02-2012, 12:03 PM
ls68firebird's Avatar
MikeFSKSpeed- i tried your website but the link to the an to oem or an to hardline shows nothing found. please list the numbers here.
thanks
-wade-
Old 04-02-2012, 07:02 PM
99VetteFRC's Avatar
thanks
-wade-
The male fittings I have are still in the box with the part number. I will post them tomorrow.
Old 04-04-2012, 02:08 PM
99VetteFRC-The male fittings I have are still in the box with the part number. I will post them tomorrow.
did you have a chance to get those numbers yet?
Old 04-04-2012, 03:05 PM
99VetteFRC's Avatar
Glad you reminded me lmao. Earl's Performance Plumbing #165106ERL.... 3/8 to female -6AN Here is a pic of the one I have still in the package. Hope it helps.
Old 04-04-2012, 03:08 PM
thank you. should help a lot.
-wade-
Old 04-04-2012, 03:10 PM
99VetteFRC's Avatar
-wade-
You're welcome. They do work great.
Old 04-05-2012, 12:13 AM
kirk69nova's Avatar
Thanks from here too 99VetteFRC. That is helpful.
Old 04-05-2012, 01:53 PM
Agent_Orange_Shuvel's Avatar
Was just looking for a solution to my setup, looks like this will do the trick. Thanks for the helpful posts guys.
Old 04-05-2012, 06:08 PM
Since we're adapting the lines here, what adapters work for the corvette fuel filter and ls1 intake quick connect? I am using a ford fuel pump but i think they use standard 3/8 and 5/16 like the corvette fuel filter. I read about some of them not locking on right and needing to be replaced.
thanks
-wade-
Old 04-05-2012, 07:59 PM
99VetteFRC's Avatar
thanks
-wade-
These should be what you want.
http://www.ebay.com/itm/Russell-6441...a07dad&vxp=mtr
http://www.ebay.com/itm/Russell-6441...9ad53e&vxp=mtr
Old 04-05-2012, 08:09 PM
do those work better than the aeromotive ones that summit and jegs sell for 35.95 ea. the ones you found look like they lock on better and they have a male AN - that's what i want.
thank you again
-wade-
Quick Reply: 1969 oem fuel line to an lines
