need room for my standup radiator...can i remove a section of the headlight bracket?
hey guys, i don't have another car locally i can look at to see if i will need this any longer but i would like to remove this section as long as it doesn't affect the headlight angle or mounting strength at all, which it doesn't seem like it would with 4 bolting points remaining. it doesn't seem to come into play at all with the headlight itself and i'm not using the stock front center bumper clips or hood latch assy. so i'm just looking for an easy shortcut.
thanks!
thanks!
I just cut my brackets the same way to move my radiator up a little more. You can see in the left side of the picture. I just clipped it with some tin snips for now to get it out of the way while I fab up everything else...
