nickcornilsen
04-01-2012, 12:06 PM
As part of my C5 suspension Nova project, i need to design a bearing retainer that will bolt to the Quicktime scattershield. The only dimension I need at this point is the bolt pattern and dowel location on the engine end of the torque tube.
The idea is that I'll have a custom shaft made that engages the corvette clutch, and goes to a GM 32 spline output, at which point I'll run a regular driveshaft to the transmission input. Very similar to the setup used on the BAD Challenger, if you're familiar with that project.
Much Appreciated!
-Nick
Much Appreciated!
-Nick
