jjcamaro02
04-01-2012, 06:40 PM
Just completed my 4L80E transmission swap, transmission has been locking up (what feels like locking up) in reverse and also when coming to a stop (below 5mph). It acts like a manual trans and engine tries to stall.
This happens once the transmission temp reaches approx. 160 degrees, below this temp there is no problem. I bought this transmission from a friend and he had a rebuild about 2000 miles ago and worked fine when he pulled it out.
The only change i made was a filter change and a new Circle D triple disc converter.
I have done data logging and it does not show converter being engaged. The force motor shows 0.10 amps and 96% line pressure when this happens. Once stopped the car is fine as soon i put it back in reverse and move it, it engages again.
I had Bill at Hp tuners do a segment swap, i am using Speartech wiring harness so no wires have been cut. I have done searches and found other people have had the same problem, but no one ever posts what the fix was.
I am at a loss on how to fix this any help would be appreciated.
Thanks in advance.
Thanks in advance.
