Wicked94z28
04-01-2012, 11:57 PM
Hey I'm in the middle of a swap and could use some tips, I have the a4 engine harness and pcm already tuned, I just swapped the pedals and the brake/clutch plug in things, made a patch panel,.bolted the shifter .assembly on and now I could use some help.....there's a plug in on the side of the shifter(i think its for reverse lights?) There's not a plug in on the m6 Interrior harness, what is it and bow do I fix it? Also i have the wire and plug in that bolts on the steering column I'm pretty sure its the.neutral safety switch, can I bypass that? Any help or pointers would be awsome!
