Dynamometer Results & Comparisons - Can't get full boost on dyno?
View Full Version : Can't get full boost on dyno?
2SSARME
04-02-2012, 03:08 AM
Have been having tons of trouble down here with dynos. There's only 1 working in the whole country right now. It's a dyno jet.
I have a pretty much everything 5th gen with a tvs2300 with a 3.4" which boosts 8 peaking at 9. We had a dyno day yesterday and I got 555rwhp@5psi. Clearly showed only 5psi being thrown on dyno. Tightened tensioners and everything as tight as could be.
Soon as we took it out on the street it was hitting 8-9 again. Does this have to do with load? I can't get the stupid thing to throw its 8-9psi on the damn dyno. I did once detuned and I hit 603rwhp, but now tuned and all I was shooting for 620-640rwhp but since it wouldn't hit its max psi I ended up only getting 555......
gectek
04-03-2012, 03:18 AM
Yes you will have to bring some type of load on it to make the max boost apparently on this setup.
turbociv910
04-03-2012, 11:54 AM
find a eddy current dyno. If the operator knows how to use it, he can load the entire run, helping your car spoool up
