Manual Transmission - transmission fluid
View Full Version : transmission fluid
fastazzls1
04-02-2012, 07:53 PM
my question is can i run gm synchromeshtrans fluid in a stock t 56 in 2000 trans am if not what are you 6 speed guys running for fluid i would like to change fluid due to its a 12 year old car and never been done thanks guys
predatorz28
04-02-2012, 10:35 PM
Yea there's quite a few people running the synchromesh in their T-56. I'm running the pennzoil synchromesh right now, which is the same as the gm stuff. It's your choice on whether or not to change it or not, though. Some people will tell you to just keep the same fluid in there since its been in there for so long, just make sure it's filled. I bought my car a year ago with 103k on it and I changed mine with no problems so far, but the fluid looked pretty fresh so it had been changed before. Your choice.
Choppers
04-02-2012, 10:43 PM
Drained mine this weekend and after seeing all the previous maintenance done by the original owner i am willing to bet this is the original fluid after 158k miles. I was having grinding issues. Put Pennzoil Syncromesh back in and its as smooth as butter and shifts perfect again. 3.8 quarts to fill. So just buy 4.
fastazzls1
04-03-2012, 07:18 PM
thanks guts will be dropping fluid this weekend how much for a quart of pennzoil and were can i get it
predatorz28
04-03-2012, 10:40 PM
I got it at napa. It wasn't cheap, like $8/quart if I remember correctly.
Fry_
04-03-2012, 11:11 PM
Although I'm sure synchromesh wont hurt anything and alot of people use it, I can't help but think that both Borg-Warner and Tremec put a bright orange stickers on T56's that say "Use Dexron 3 ATF only".
oldmano2z
04-03-2012, 11:16 PM
this is true but, i run gm syncromesh for the fact that it does not break down. thats just an opinion.
calhoon
04-04-2012, 09:59 AM
Also, Synchromesh is a thicker product and can cause some cold shift issues.If you don't mind letting it warm up, there is no issue.
autogeek23
04-04-2012, 10:09 AM
about to fill mine with dex 3, woto woot
fastazzls1
04-04-2012, 08:06 PM
what about dex3 synthetic
hcb1700
04-05-2012, 12:56 AM
We put DexronVI on my brothers M6 '01 Camaro and it's been running stronger then ever.
hcb1700
04-05-2012, 12:57 AM
Oh, DexronVI is synthetic too.
Ruthless909
04-05-2012, 07:21 AM
+1!!!!
It was placed there for a reason. :chug:
Rare96LT1Formula
04-05-2012, 07:36 AM
Pennzoil Syncromesh here. Love it. 113K miles
