Fueling & Injection - H/C LS6, which injectors?
View Full Version : H/C LS6, which injectors?
RADEoN
04-02-2012, 09:24 PM
I purchased a H/C setup for my LS6 CTS-V, it's a TSP MS3 cam, PRC stage 2.5 heads, and supporting mods (new lifters, upgraded rocker arms, comp rods, etc.), I want to get the new injectors in before my dyno tune, and am looking at a set in the FS/FT section (http://ls1tech.com/forums/parts-classifieds/1524439-40lb-injectors.html). I've been unable to find anything on part# 01D114B, except, that it may be (http://ls1tech.com/forums/fueling-injection/1314568-racetronix-37lb-question.html) a Racetronix brand 37lb injector (http://www.texas-speed.com/p-247-racetronix-ls1ls6-37-lbhr-fuel-injectors.aspx).
I also intend on adding a ported throttle body prior to my dyno tune.
Does anyone have any input?
spordee1
04-08-2012, 07:17 PM
Hello RADeon: I installed a MS3 Cam, with 12:1 CR, used new CTS-V lifters and then decided to use Lunati 72532 lifters. LS6 (347 CI) engine. I also used 43# green top injectors
01M6TA
04-08-2012, 07:24 PM
first off why are you typing in bold? second he said "injectors" not "lifters". if you can afford down time, i would send your stock ones to FIC and get them resized and flow matched. I think it cost around $250, not sure though. also i think he can make them up to 42lbs.
