Has anyone used a summit clutch pedal and master cylinder pro pack?
I came across this clutch pedal and wildwood master cylinder combo on summit (link below) and was wondering if anyone had used it on a ls1 T56 swap. Based on my research the master has the right specs for the application and I think it would be easier to install than a fbody clutch pedal.
http://www.summitracing.com/parts/CMB-14-0011/
I used the Wilwood and Turbo coupe pedal setup. If I did over I would not bother trying to find the Turbo coupe pedal ***. and just fab up an arm like Zipster came up with.
