Automatic Transmission - Where to buy 4L60E PARTS?
CLRD4TO
04-03-2012, 09:00 AM
My trans died on my truck over the weekend and Im going to rebuild it myself. My first auto rebuild so I havent had to search for this stuff before. Im having a hard time finding a 1-stop .com shop to buy everything I need for a good price. I can find a couple parts at one, more at another, then shipping outweighs any savings from one site to another. Ive searched on google and sponsors here, I either find complete rebuild services or just a couple parts available. Im looking for a rebuild/seal kit, good clutches, transgo hd2, corvette servo, the beast, and maybe the "code buster" tcc valve. I might need more depending on tear down.
Any help is appreciated!
69cutlassrkt
04-03-2012, 12:49 PM
have you tried pro-built automatics?
DJNight2k
04-03-2012, 04:27 PM
Check out http://www.transmissioncenter.net they have a decent selection of upgrade parts and overhaul parts as well.
mrvedit
04-04-2012, 08:16 PM
My first choice for parts is always:
http://www.transmissionpartsusa.com
Excellent pricing, huge selection and free shipping over $60.
They carry many of the Sonnax parts for 4L60E.
However, if you call them they cannot give you any advise; it is just a warehouse.
My second choice is:
http://www.trutechtrans.com
(Also seller on ebay)
Not the absolutely lowest prices, but close.
Excellent source of genuine GM/AcDelco parts. Owner is easy to reach and very knowledgeable with good advice. (Also not cocky or opinionated.) I am always happy to spend a few extra dollars in exchange for the generous advice.
I have bought from transmissioncenter.net, but their website is horrible and shipping prices are very high.
DJNight2k
04-04-2012, 08:29 PM
I will agree their website is pretty annoying lol. I usually use dean transmission parts when I do rebuilds but they don't have an online store just phone.
harry k
04-06-2012, 07:26 PM
here is who is refreing to
https://www.700r4l60e.com/store/home.php?cat=22
CLRD4TO
04-06-2012, 08:19 PM
Thanks for links guys. I did check out most of those and called a couple places. Problem with calling race shops is being recommended unnecessary go fast parts for just a stock truck.
Ended up going to WIT locally. They do have a site wittrans.com but not really newb friendly. Also got in touch with a local trans builder and steered me in a different direction. Bushings, bearings, hardened shell, band, and sonnex tcc and afl valves. No vette servo or transgo.
camarogurl74
04-06-2012, 08:35 PM
There is a transmission part place on Shaver in the industrial buisness building it is good priced when we had to rebuild our transmissions thats where we went.
Rachelle
SS SLP2
04-06-2012, 10:06 PM
I got it all at transtar1.com
OP pm me for more info to idenentfy parts
Johnny
mrvedit
04-06-2012, 10:17 PM
Thanks for links guys.... Also got in touch with a local trans builder and steered me in a different direction. Bushings, bearings, hardened shell, band, and sonnex tcc and afl valves. No vette servo or transgo.
I think he steered you in the right direction. You might consider the vette servo though, its only $20. You can change it without removing the trans (unless an extremely tight fit).
IIRC, the Sonnax tcc and afl valves require very expensive Sonnax reamers ($150 each); if true, you might consider asking your local builder to rebuild the valve body for you. I also see supposedly rebuilt valve bodies on ebay for less than $200. A bad afl valve can quickly ruin a rebuilt trans, so don't skip this step.
CLRD4TO
04-07-2012, 10:08 AM
He has all the tools and is doing the bushings, reaction planetary bearing, and valves. Been doing this for 26 yrs and last 2 yrs out of his garage. Honest and charges half of a normal shop rate and his business only comes from referrals. Earned my trust and Im still on the fence for the vette servo. Said he's installed a few by customer request and personally didnt like the shifts.
SparkyJJO
04-07-2012, 10:56 AM
I used the Transgo SK-4L60E kit to repair/replace the bad TCC valve in my 4L60E. Worked like a charm and did not require any fancy expensive reamers or anything. I put the same thing in my Trailblazer's 4L60E when I did a fluid change, just to prevent any damage from happening later as I want it to last past 200k miles. Installed at 120k miles, truck now has about 158k miles.
If he's doing all the work however he's got the stuff to install the Sonnax TCC. The Transgo kit is good for the home DIYer.
mrvedit
04-07-2012, 05:59 PM
Sounds like a lucky find. My local trans builder that I chat with regularly says he put the Corvette servo into most of his stock rebuilds with no complaints.
The Corvette servo has more holding power on the band in 2nd and 4th gear. This can be useful in a truck that is pulling a trailer, especially with hills. If the band slips, it will wear out quickly. Your builder might be saying that the shifts are firmer than stock; the fact that you are on this forum indicates you probably wouldn't mind that. Softer accumulator springs might soften the shift, tuning the ECU can also soften the shifts.
Kirby
04-13-2012, 10:06 AM
Try 4l60-e.com. Tons of high quality parts there. I've been looking at their stuff for over a year now. I too will be attempting my first auto trans rebuild in a month or so. Best of luck to you on your rebuild!
CLRD4TO
04-13-2012, 11:52 AM
Look for a local builder that you can take parts to. Specials tools are needed and tips are priceless. Still getting the build done for less than half of the lowest rebuild quote I got.
CLRD4TO
04-16-2012, 10:39 PM
Trans rebuild is a success. Shifts are slightly more firm but smooth. In fact, the wife didnt even notice a difference in shifts. Im glad I did put the servo in.
Kirby
04-17-2012, 09:31 AM
Glad to hear! Hopefully I can find a local tranny shop that wouldn't mind letting me dive into the rebuild with them in return for a discounted rebuild cost. Would love to get some hands on A4 experience. Not to mention I've already got $1400 worth of high quality parts I'm wanting to put in. What all did you replace in yours and what did you upgrade?
CLRD4TO
04-17-2012, 11:36 PM
Needed for failed parts
Rebuild kit with hi-energy clutches, 3-4 steels, plates, and retaining ring. Input drum piston set, 3-4 clutch booster springs. Forward sprag.
Upgrades
Vette servo, Sonnex TCC and AFL valve kits, hi-energy 2-4 band
Preventative maintenance
Reman torque converter. Hardened sun shell (supposedly 03+ is factory hardened). Aluminum forward and 1-2 accumulator pistons, Bushings: Stator support, pump, and case. Bearings: planets and input drum
Lowest rebuild quote (locally): $1200
Parts and pro help labor total: $580
I had a few days of not touching anything since life gets in the way like that, but start to finish was 2 weeks. Would I do a job like this again? Sure, but I wouldnt go out of my way to get a side job like this!
Kirby
04-18-2012, 10:04 AM
Sounds like you had a pretty budget rebuild. I'm looking at $1400 so far just in parts alone. But that also includes a new $600 converter. How difficult would you say the rebuild was? I am descently knowledgeable regarding cars and learn everything I don't know very fast. Hoping a 4L60-E manual as well as a rebuild DVD should make it pretty fool proof. Just not sure what special tools I might need.
CLRD4TO
04-18-2012, 09:27 PM
I had access to alldata and briefly looked at an ATSG book. You will definitely need something, and browsing forum hits on google gets frustrating. Disassembly is very easy. Need a T50+ torx and a lock ring pliers. Access to a parts cleaner will save time, shop rags, brake clean, and your lungs!
You will need a variety of tools for repair/assembly, or like me, find someone to do it for you. Need a press tool to compress the clutch spring packs. Not needed but helps, is a hole in your workbench to work on the input drum. Rubber tip on an air nozzle for leak testing pistons. Feeler gauge for clearances. Lip seal install tool. If you need/want to replace any bushings, there are several install tools for them. If you upgrade to sonnex valves, reamers are needed to enlarge the holes. Valve body and case needs to be flat, my builder used a large knife sharpening stone to sand the highs down. Lastly are the teflon seals, which are a bitch. Theres a plastic cone tool to install them and another to shrink them to size. I had one that still didnt want to set when installing the oil pump, a tyrap and 10 minutes was the trick to shrink it down!
mrvedit
04-19-2012, 12:12 PM
This book is EXCELLENT with step-by-step quality color photos:
GM Automatic Overdrive Transmission Builder's and Swapper's Guide (S-A Design) by Cliff Rugles
The best $17 you will spend and IMHO more useful to the 1st-time builder than the ATSG manual:
http://www.amazon.com/Automatic-Overdrive-Transmission-Builders-Swappers/dp/1932494502/ref=sr_1_4?ie=UTF8&qid=1330729393&sr=8-4
It takes at least $200 in special tools to rebuild a trans. And that assumes you have a complete set of shop tools, assorted snap ring pliers, feeler blades, etc.
See this thread and my pictures (post #3):
http://ls1tech.com/forums/automatic-transmission/1511061-need-4l60e-tools-where-can-i-get-them.html
And of course everything that CLRD4TO mentions. The tools for Teflon seals are $350 or you can have a local shop do it for you, or take a chance without the correct tools. I would highly recommend getting a quality rebuilt valve body or having an expert rebuild it for you. (The two Sonnax reamers are another $400 and require practice.)
Just buying $1400 of parts is not going to guarantee you success. Some parts work better together than others. The parts selection will also determine how the shift kit is installed and which options are selected; this is much too complex for simple Q/A.
Kirby
04-20-2012, 03:05 PM
I completely agree. I will definitely have to get some experienced knowledge on how to configure the shift kit, etc considering the new parts I've been looking at might make my shifting so firm that I may only need the softest spring. The billet servo I'm even looking at has 35% more holding power than the corvette servo.
I did just order that book btw. Along with 4 other books and miscelaneous tools. lol.
Lots of great info here too as to where the best places to order parts can be found. Glad I came across this thread!
