tt383lt1
04-03-2012, 02:34 PM
has anyone ever done a mini tub on a 4th gen? i Figured there probley not that hard to do. knowing i can do sectioning pretty easly. but i figured it will never hurt to get some hints befor i do it.
the only tools i have at home are a sawall and a cut off wheel. and a seam buster. i do not own a plasma cutter. ( if it come down it i can rent a plasma cutter for $50 for the weekend.)
the only question i have is how do you bond the 1/4 panel to the mini tub. i heard if you weld it you will have to repaint it due to the heat. i heard of people using fiberglass to bond them and some people use seam seal to bond it ( i dont think seam seal would work. knowing its to flexable to bond and hold). but i am seam sealing everthing when i get done i just dont think it will hold up by it self to the 1/4 panel and mini tub.
but im leaning tords fiberglassing it. any insight?
