Suspension & Brakes - Caliper bolt size???
View Full Version : Caliper bolt size???
ZeeSNuttS
04-03-2012, 04:39 PM
Tring to find out what size the 2 caliper bolts are on a 2001 Z28. Thx for any help!
David
ZeeSNuttS
04-03-2012, 08:27 PM
NVM......M8 X 1.25; length 25mm, grade 10.9.
wssix99
04-08-2012, 09:56 PM
This has some good information on the bolts. Not sure if you want front or rear - they are different sizes. http://ls1tech.com/forums/suspension-brakes/1186740-dont-let-your-friends-work-your-brakes.html
BTW - More important than the size is the size/strength. If you put a regular bolt on there, it will snap like a piece of spaghetti. Lots of threads where people have lost calipers while driving. (Not pretty.) I'd recommend getting the bolts from the dealer.
ZeeSNuttS
04-09-2012, 12:12 PM
I'm doing C5 rotors with my oem LS1 calipers, I need longer bolts for the C5/brackets so they will fit. I thank you for the extra info, I got lucky and found caliper bolts here at my work, which are longer and grade 10.9 :)
I should have added the grade bolt you need for calipers in the 2nd post on this thread.
