View Full Version : Help w/ removig torque arm and bushing
chevystyle
04-03-2012, 06:18 PM
Do I need to let the axle hang (frame on jack stands) or just back the Camaro up onto ramps and keep the weight on the suspension??
Also, how to do an R&R on the new poly bushing??
Thanks.
96RamAirTA
04-03-2012, 06:27 PM
When I did mine I used a lift and unbolted it then had to use a screw jack to take the tenson off the TA, then you kinda gotta twist and pull to get of out. As far as the mount its a bitch 3 bolts on tail of transmissions. If u can unbolt the trans crossmember and lower the trans a lil bit might make it easier
need4fun2469
04-03-2012, 08:59 PM
I let my axle hang when I swapped mine out. I trimmed some of the poly mount to allow the clam shell to close around it.
