600 horse?
Old 04-03-2012, 07:46 PM
mprete's Avatar
Default 600 horse?
is 600 horse achievable on stock heads and crank? and be reliable?
Old 04-03-2012, 07:52 PM
BlueBird346's Avatar
Not NA. You talking wheel horsepower? You will need spray or boost, or a big cube motor. I think the max out of a stock cube LS1(from what ive seen) is low 5s, with NICE heads($$$). And that will be a somewhat radical setup.
600 should be easy if your not planning on staying NA.
Old 04-03-2012, 07:53 PM
msydow's Avatar
I would say yes if you were adding a turbo but I am guessing you are looking for fwhp?
Check out the guys in the stock bottom end section. Really need more details about what
You are do
Old 04-03-2012, 08:03 PM
Ph.D. in HUBRIS
custm2500's Avatar
Not to be a dick but I would be confertable in saying the OP is dreaming. That is why there are no detail besides a HP number.
Old 04-03-2012, 08:10 PM
LS-ONE_DAY's Avatar
Buddy of mine wanted an NA 600rwhp car, he ended up getting a 427 stroker to do it
Old 04-03-2012, 08:12 PM
mprete's Avatar
haha i have an LS1 from a 02 corvette. its going in my 66 nova next year. im building the motor this winter. will be twin turbo set up. its all stock motor. thats why im asking if its achievable with stock heads and crank. i didnt see the stock lower end section, i will check that out.
motor had piston slap when pulled so it will be bored probably 30 over and ill do a nice piston and maybe rods if I need them. but i dont know what a stock motor can handle and thats why im asking.
Old 04-03-2012, 08:14 PM
mprete's Avatar
oh and im looking for 600 at the crank. 550 at the wheels.
Old 04-03-2012, 08:21 PM
COPO9560's Avatar
You can't bore a LS1 block 030 over - sleeves are way too thin. For turbo you should consider forged pistons and rods. Suggest you check out the FI section of forum and do more research.
Old 04-03-2012, 08:22 PM
redtan's Avatar
You sure can take it there with a turbo, twin screw or centri.
How reliable it will be will greatly depend on the tune and other supporting mods you do.
Old 04-03-2012, 08:24 PM
Ph.D. in HUBRIS
custm2500's Avatar
Why would you do twin turbos and only look for 600 hp? You can easily make a very drivable single turbo and the bottom end should be fine. You would be wasting your time and money to do twins. The money for a second turbo could be put into more usefull parts if you are only looking for around 600 or so hp.
Old 04-03-2012, 08:29 PM
mprete's Avatar
ill move over to the FI section and check that out too. I am planning on doing 2 smaller turbos more so the balance of stuff under the hood looks nice. also im only shooting for 600 horse because its a street car and I drive it a lot. is on a 10.5 tire and stock the car weighs 2700 lbs with a 327. ill be at about 2500 lbs. anything more than 600 horse will be to much for this thing to handle on the street. thanks guys.
Old 04-03-2012, 10:56 PM
01ssreda4's Avatar
This ain't your grandpa's 3 fiddy.
