mallder
04-04-2012, 08:46 PM
Hi there. New guy here.
I've aquired an 07 ly6 as the basis for an upgrade for a 71 chevelle.
I need advice and council regarding choosing a suitable combination.
Heres what I want.
1. a daily driver that will support power brakes.
2. greater than 400 hp at the wheels (the more, the better)
3. Reasonably tuneable. want a smooth driving engine with out any major holes in the tune.
Here's what i have.
1. iron 6.0 block, stock crank, rods and pistons (ly6 with 108,000 miles in great shape, no cylinder ridge, no bad bearing wear).
2. stock lifters, and rockers (both appear to be in good shape)
3. stock l92 heads.
4. stock ls3 intake with ly6 MAF and throttle body
5. engine will be powering a 3800 pound chevelle through a t56 and a 3.36 rear end
Here's what I dont want to spend money on to change.
1. I want to keep the block and I dont want to bore it more than absolutely necessary. (I want the option to do another rebuild later)
2. I'd rather not change the rods but recognize that piston selection is limited for stock rods (why is this??)
3. I think I can be happy with the power availible from the stock stroke, so I would rather not change the crank.
Help me select the following
1. Cam, standard or VVT.
2. Head milling? if so how much?
3. valve springs
4. pistons, keep the small dish stock pistons or bump up compression for a more radical cam.
5. fuel injectors. what will stock ls3 injectors handle?
Help me build this thing, what would you do and why? all ideas welcome.
Clark
Heres what I want.
Here's what i have.
3. stock l92 heads.
3. valve springs
Clark
