how do i know if my rockers are properly on
i am looking at the rocker arms right now and they move side to side no up and down movement is this normal engine torqued to 22 ftlbs
wait are you saying that they are snugged/torqued down, there is no play between the push rod and the rocker nor is there any play between the tip of the valve and the rocker. but your wondering if the slight side to side movement that your feeling is normal?
if the movement is ever so slight and the valve is fully closed then yes you should be able to wiggle the stock rocker side to side a tiny bit even when torqued down
yes that is what i am wondering about i am using m brothers account, i am a ford man who has been converted sold my terminator to buy an 02 SOM ss i am fixing a buddies helping] anyways so i can learn the rockers are torqued to 22 ft lbs and move side to side a bit also there is a noise that sounds valvetrain related so we checked for bent pushrods and loose rocker arms reinstalled same noise still present
Did you follow the rocker installation procedure in the service manual? There will be some side to side motion with the valve closed, however there were also issues with the stock rockers losing needle bearings. This might be the source of your noise and if there is unreasonable movement of the rocker missing bearing would explain that as well.
