PartsTaxi.com
04-04-2012, 09:01 PM
****New Offerings****
Yella Terra Ultralite Series
1.7 Ratio Adjustable LS2 Roller Rocker Set (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=997768&siteid=215330&catalogid=6984) - YT6638 (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=997768&siteid=215330&catalogid=6984) - $549.80
1.7 Ratio Non-Adjustable LS2 Roller Rocker Set (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=997769&siteid=215330&catalogid=6984) - YT6645 (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=997769&siteid=215330&catalogid=6984) - $419.88
1.8 Ratio Non-Adjustable LS2 Roller Rocker Set (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=997770&siteid=215330&catalogid=6984) - YT6646 (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=997770&siteid=215330&catalogid=6984) - $419.88
1.8 Ratio Non-Adjustable LS7 Roller Rocker Set (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=997771&siteid=215330&catalogid=6984) - YT6670 (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=997771&siteid=215330&catalogid=6984) - $559.90
LS Valve Cover Spacers (Required for YT6638) (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=997772&siteid=215330&catalogid=6984) - YT5123 (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=997772&siteid=215330&catalogid=6984) - $199
2012 Centennial Wheels
http://www.partstaxi.com/sfimages/215330/partimages/Q5V.jpg
Machine Faced Cup Wheel - Q5V
Front - 9598727 - $513.73 each
Rear - 9598731 - $545.39 each
http://www.partstaxi.com/sfimages/215330/partimages/RUR.jpg
Black Cup Wheel w/ Red Stripe - RUR
Front - 9598725 - $539.88 each
Rear - 9598729 - $568.68 each
http://www.partstaxi.com/sfimages/215330/partimages/RUV.jpg
Black Cup Wheel w/o Red Stripe - RUV
Front - 9598726 - $489.48 each
Rear - 9598730 - $509.88 each
Centennial Edition Center Cap- 9599004 - $14.89
2012 Seat Conversion Package
This is a complete kit of all OEM GM parts needed to convert your 2005-2011 C6 to the new design 2012 C6 seats.
Package Includes;
All 6 Seat Covers
All 6 Seat Pads
Seat Back Release Handle, Cable & Bezel
Updated 2012 C6 Seat Conversion Kit (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=973278&siteid=215330&catalogid=6984)- $1280.38
+$50 for Alcentera (Suede)
+$153.90 for new Seat Heater Elements
You can order through THIS LINK (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=973278&siteid=215330&catalogid=6984)
--------------------Interior Upgrades------------------------
HEADS UP DISPLAY COMPLETE KIT (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890965&siteid=215330&catalogid=6984&referrerid=1500922)- $368.66
Ordered WAY more than needed for the Black Friday sale, and they need to go!
Click on the name of the kit to link directly to our site to order.
This kit includes;
HUD Display
HUD Switch
HUD Bezel
Custom Wiring Harness
2 6mm nuts
1 Bolt
1 J Nut
6 Wire Quick Splice Connectors.
----------------------GM Performance Parts----------------------
Bare Engine Blocks
Aluminum C5R Racing Engine Block (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890259&siteid=215330&catalogid=7440&referrerid=1500922) - 12480030 - $6997.75
LS7 Engine Block (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890256&siteid=215330&catalogid=7440&referrerid=1500922) - 19213580 - $2685
LSX 376 Engine Block (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890266&siteid=215330&catalogid=7440&referrerid=1500922) - 19244055 - $2369
LSX 454 Engine Block (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890268&siteid=215330&catalogid=7440&referrerid=1500922) - 19244057 - $2369
LSX Tall Deck Engine Block (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890264&siteid=215330&catalogid=7440&referrerid=1500922) - 19244059 - $2258
LSX Bowtie Engine Block (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890262&siteid=215330&catalogid=7440&referrerid=1500922) - 19213964 - $2039
LS2 Engine Block (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890249&siteid=215330&catalogid=7440&referrerid=1500922) - 12602691 - $1099.98
LS1/LS6 Engine Block (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890239&siteid=215330&catalogid=7440&referrerid=1500922) - 12561166 - $979.88
GMPP Cylinder Heads
All Cylinder Heads are priced as each
CNC Porter LS6 Race Cylinder Head (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890277&siteid=215330&catalogid=7440&referrerid=1500922) - 88958622 - $1099 each
LSX-L92 Small Bore Cylinder Head (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890291&siteid=215330&catalogid=7440&referrerid=1500922) - 19201807 - $789.88 each
LSX-LS3 Cylinder Head (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890294&siteid=215330&catalogid=7440&referrerid=1500922) - 19201805 - $919.88 each
LSX-CT (Circle Track) Cylinder Head (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890462&siteid=215330&catalogid=7440&referrerid=1500922) - 19166981 - $1690.88 each
LSX-DR (Drag Race) Cylinder Head (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890463&siteid=215330&catalogid=7440&referrerid=1500922) - 19166979 - $1690.88 each
LSX 4.125 Stroke Crank Shaft (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890265&siteid=215330&catalogid=7440&referrerid=1500922) - 19244018 - $1220
24x Reluctor Wheel for 97-04 (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890275&siteid=215330&catalogid=7440&referrerid=1500922) - 12559353 - $15.75
58x Reluctor Wheel for 05 & Newer (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890276&siteid=215330&catalogid=7440&referrerid=1500922) - 12586768 - $16.88
LSX 6.000 Connecting Rod Set (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890251&siteid=215330&catalogid=7440&referrerid=1500922) - 19166964 - $419.90
GM Performance Parts Cams - Please click on the links to view exact cam specs.
Hot Cam Kit (http://www.trademotion.com/partlocator/index.cfm?action=MorePartInfo&PartID=857745&siteid=215330&catalogid=7440&referrerid=1500922) - comes with Hot Cam, 16 LS6 Valve Springs and Retainers - $468
GM Performance Hot Cam (http://www.trademotion.com/partlocator/index.cfm?action=MorePartInfo&PartID=857739&siteid=215330&catalogid=7440&referrerid=1500922) - 88958733 - $399.71
GM Performance LS Stage 2 Cam (http://www.trademotion.com/partlocator/index.cfm?action=MorePartInfo&PartID=857749&siteid=215330&catalogid=7440) - 88958722 - $399.71
GM Performance LS Stage 3 Cam (http://www.trademotion.com/partlocator/index.cfm?action=MorePartInfo&PartID=857751&siteid=215330&catalogid=7440&referrerid=1500922) - 88958723 - $399.71
LSX 454 Cam (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890512&siteid=215330&catalogid=7440&referrerid=1500922) - 19166972 - $269
Valve Train
Racing Hydraulic Roller Lifter Kit (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890619&siteid=215330&catalogid=7440&referrerid=1500922) - 88958689 - $249
LS Stock Replacement Lifter Set (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890620&siteid=215330&catalogid=7440&referrerid=1500922) (16 lifters) - 12499225 - $125
LS "Bee Hive" Valve Spring Set (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890622&siteid=215330&catalogid=7440&referrerid=1500922) - 12499224 - $55.38
LS High Volume Oil Pump (http://www.partstaxi.com/partlocator/index.cfm?action=MorePartInfo&PartID=890313&siteid=215330&catalogid=7440&referrerid=1500922) (LS1/LS2/LS6) - 17801830 - $71.88
Package Includes;
All 6 Seat Covers
All 6 Seat Pads
This kit includes;
HUD Display
HUD Switch
HUD Bezel
2 6mm nuts
1 Bolt
1 J Nut
Bare Engine Blocks
GMPP Cylinder Heads
Valve Train
