Fueling & Injection - Racetronix fuel pump question??
suvettetexas
04-04-2012, 11:30 PM
I just installed a new performance Racetronix fuel pump FPA001 and a new pump assembly/module from Racetronix into my 2002 firehawk, i now have to crank the car longer to get it to start than before, sometimes takes a little while, is this Normal ???? thanks
Racetronix
04-05-2012, 12:57 PM
Did you register for help in our support forum?
suvettetexas
04-05-2012, 10:54 PM
No, didnt know there was one, but ill look, thanks
NHRATA01
04-11-2012, 02:59 PM
If you can get a fuel pressure gauge on there and watch what it does as you crank, that will help diagnose.
For whatever reason, for about the first month I was running the racetronix setup, the fuel pressure would quickly bleed off after the pump cycled (in fact I think I posted a thread about this years ago, and the consensus was the racetronix check valve didn't work that well). If the car sat overnight, I would have to turn the key once to prime it, cycle it off, and then turn the key again to fire it right up, otherwise it would take a hair longer to crank. But even not doing that the crank time wasn't excessive, just longer then was typical with the factory pump. Surprisingly enough, the problem mysteriously went away after a month or so. 5 years later, the racetronix is still working flawlessly.
aerojt
04-16-2012, 06:34 PM
Where is this support forum? I am in the middle of my install and I have only a one wire ground off the fuel pump, is this new? The instructions say two black wires going to the ground, but mine only has one on the racetronix unit. Thanks
Racetronix
04-16-2012, 06:38 PM
Did you purchase this kit directly from us?
Racetronix
04-16-2012, 06:39 PM
Junk got into your fuel system which hung up the check-valve, bypass valve or regulator. It was purged and caught in your filter.
aerojt
04-19-2012, 07:29 PM
I got it from the ws6store, not sure if that helps me or not. Thanks!
JUSTINSWS6
04-19-2012, 07:35 PM
I got mine from ws6 store about a month ago works fine.
needtransam
04-20-2012, 11:33 AM
How do you check these items to make sure their is no junk and evade any possibility
Racetronix
04-20-2012, 11:39 AM
Clean the tank.
Replace filter.
Do not allow any dirt to get into pump pickup.
Nasty N8
04-20-2012, 01:41 PM
Reason #1 to drop the tank to clean it when replacing.
needtransam
04-20-2012, 04:06 PM
I can't drop my tank what options do i have of cleaning the tank??
Also how can I check for proper clean lines and to make sure the pick up tube works as well as the lines are getting proper fuel?? can you prime the pump manually?
