A-body p/s hose configuration pics
Old 04-05-2012, 11:23 AM
kballs's Avatar
Default A-body p/s hose configuration pics
I've been combing through peoples swaps and haven't found any clear pics of the p/s lines. I'm thinking about using aeroquip -6 lines and fittings to make it as clean as possible.
Anyone got a link of some photos?
Old 04-05-2012, 12:01 PM
Project GatTagO's Avatar
Received 1,392 Likes on 879 Posts
Go to your local industrial hose vendor. They will be able to make you a very good high pressure, reinforced, rubber hose with AN fittings. The "racing" braided hose can transmit a lot of noise through the power steering system.
Andrew
Old 04-05-2012, 12:05 PM
99VetteFRC's Avatar
If you are using truck pump, take the fitting out of the back of the pump (1" wrench) and swap it with the one in the origional pump. then the stock A-body power steering hoses screw right in. No need to spend funds.
Old 04-05-2012, 03:29 PM
chuckd71's Avatar
Or pick up a grand cherokee steering box.
Old 04-05-2012, 03:43 PM
68BBChevelle's Avatar
I did a GC box swap when i did my ls swap, it works great! I just used the tuck pressure hose for the high side and used some -6 an i had left over for the return.
Old 04-05-2012, 08:01 PM
99VetteFRC's Avatar
I'm still running the Abody box. I bought a remanned unit about 3 yrs ago. Can't see replacing it yet.
Old 04-05-2012, 08:31 PM
kballs's Avatar
Default strg
I've got a GC box going into it at the same time. I also ordered 2 sets (for some reason) of the lee adapters that press into the box to make them back into the old style inverted flare. I guess i'll wait until the engine i in for the last time and either make up a line or try to match up an oem one that looks like it belongs there.
Old 04-05-2012, 09:02 PM
99VetteFRC's Avatar
I just went out in the garage and took these pic. Not the greatest but may help.
Attached Thumbnails A-body p/s hose configuration pics-dscn1250.jpg   A-body p/s hose configuration pics-dscn1248.jpg   A-body p/s hose configuration pics-dscn1246.jpg   A-body p/s hose configuration pics-dscn1245.jpg   A-body p/s hose configuration pics-dscn1244.jpg
Old 04-05-2012, 11:41 PM
bczee's Avatar
Here is a picture of my high pressure side, used Russell Fitting and adaper with Russell Teflon SS Braided hose.
Pump with 16mm 0-Ring to AN Adapter
Inverted Flare to AN
BC
Old 04-06-2012, 12:21 AM
kballs's Avatar
Yeah BC, that's what i'm thinking. That way you can make it a nice length with enough slack for engine movement, but not a huge loop like the other thick rubber press. side hose.
Thanks guys
Quick Reply: A-body p/s hose configuration pics
