General Maintenance & Repairs - battery is dying overnight
k_garretson23
04-05-2012, 11:31 AM
My battery in my ws6 has been dying when sitting for a few hours. I tested my alternator, its good, and the battery isnt very old. What could be killing my batter? I did the wire mod a few weeks ago and havent had the problem until the past few days could this have something to do with it?
1ltcap
04-05-2012, 11:35 AM
what is "the wire mod"?
if you're going dead in just a few hours, that is an enormous draw.
couple easy ways to check......test light between either battery cable, and its terminal. that much of a draw's gonna have it lit pretty bright. once you confirm that, unplug the alternator. all of its wires. if the light goes out, the alternators voltage regulator has failed. if not, move to the fuse blocks. pull 1 fuse at a time till the light goes out. that'll tell you the circuit that's drawing.
also, check your glovebox light, hood and hatch lights. make sure none of them are staying on.
Jersey Mike
04-05-2012, 11:45 AM
When doing the !Wire mod, did you relocate the battery ground?
k_garretson23
04-05-2012, 11:50 AM
The wire mod where you move the main wire harness into the fenderwell and relocate the grounds. Its dying like over night or while Im at work on an 8 hour shift. When I jump it it takes a second then fires right up.
http://i74.photobucket.com/albums/i273/kjgj9-23-92/431981_3045169845868_1161804630_32457345_175212282 7_n.jpg
picture of wire mod. I put my ground on the top tcs bolt. Its not loose and like a said i did this a few weeks ago without issue.
Fosnot
04-05-2012, 10:35 PM
Did you put any insulation or rubber grommets around the hole you cut for the wires?
k_garretson23
04-07-2012, 07:28 PM
yeah i cut a vaccum line and put it around the whole
FiredUpZ28
04-10-2012, 03:32 PM
Retrace your mod steps. Otherwise, set an ammeter up for a draw test and start pulling fuses.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
