EugThinks
04-05-2012, 02:02 PM
Man, I haven't logged in here in a looong time. I miss this place.
Anyway, I've had a gas mileage problem for a while now. Normally my 2000 M6 SS gets around 24mpg; with this issue it's down to around 16-17. It's been going on for some years now; between life things and other mechanical things with the car I'm only really getting around to trying to figure it out now.
There have been no driveability issues; everything feels absolutely normal. No codes, no gas smell, all emissions measures are normal. I cleaned the MAF sensor, no change. I haven't tried changing out the MAP or O2 sensors, but with no codes, no weirdness in emissions or how the engine's running, and no degradation over the past four years, I'm skeptical that they're the problem. I had the spark plugs and wires changed about 1.5 years ago, no change. The other strange thing is that the fuel gauge appears to be dropping while the car's parked. I'll drive the car and leave it and look at the fuel gauge, and when I start it later the gauge will be 1/32-1/16 tank lower than it was. I have no idea if this is just the gauge being weird or if I actually have a fuel leak somewhere or what.
In the past six months or so I've noticed the engine heating up a lot faster than usual, at least according to the dash gauge. It isn't overheating, just warming up significantly faster than before and then staying at a stable temp. Again, no codes, no driveability issues, coolant level is fine and I can't find any evidence of leaks external or internal. I don't know what's going on, but my idle thinking makes me suspect that something's making the car run extra-rich, causing both the temperature and gas mileage differences.
Searching for these various symptoms hasn't gotten me anywhere. Anybody have any insight for me? Thanks in advance!
