Cam swap electrical issue
Old 04-05-2012, 02:11 PM
Cstone812's Avatar
Default Cam swap electrical issue
So finally finished my cam swap last weekend which included the MS3 cam with all the supporting mods oil pump ud pulley timing chain etc etc. well the car is running great for being untuned but the only problem is I noticed my fog lights are not turning on nor is my asr turning on it just says asr is off in the dash the whole time and the switches do not light up. Ive checked the fuses and relays for both and they are good I am lost as to what I might have done. Any help is appreciated.
Old 04-06-2012, 12:26 PM
RARON455's Avatar
Are you certain that you put all the grounds back..there are some on the back of the drivers side head, and on the front core support by the airbox tray..
Old 04-11-2012, 10:59 PM
Cstone812's Avatar
All of the grounds are back in and on....funny thing is is that I have noticed the asr switch will light up and turn on whenever i start the car but it only stays on for like 4 seconds then goes off and wont come back on...same goes for the fogs...could a ud pulley be affecting this?
