Lightest LS1 replacement Rod
Old 03-25-2004, 10:42 AM
DynamicZ28's Avatar
Default Lightest LS1 replacement Rod
Outside of an Aluminum Rod what are the lightest rods you can get for an LS1 replacement. 6.125 is the length I believe
Old 03-25-2004, 10:46 AM
DenzSS's Avatar
That is a good question. I'm curious to know that as well. I know my Dyers Top Rods are ~660g.
Old 03-25-2004, 01:48 PM
Cstraub's Avatar
Lentz or Carrilo can get in the 500 to 520 gram weight. The Jager rod, transformed aluminum is around 430gms.
Chris
Old 03-25-2004, 03:05 PM
DynamicZ28's Avatar
Lentz or the Carillo are what material? The Jager is a little pricey for me
Old 03-25-2004, 03:28 PM
DenzSS's Avatar
A top quality rod from Carillo, Dyer, or whoever is going to cost you in the neighborhood of $1600. If you get really exotic, they can get close to $2000.
Old 03-25-2004, 04:20 PM
Blorton's Avatar
Any Ti options out there?
Dan
Old 03-25-2004, 04:37 PM
Cstraub's Avatar
Sure, Crower and several others, about 3K.
Chris
Old 03-25-2004, 07:05 PM
Restricted User
CAT3's Avatar
Chris, Cstraub, any idea on weight, longevity, revving advantages of the Ti over traditoinal?
Old 03-25-2004, 07:07 PM
Uthinkso's Avatar
I'd say Carillo or Oliver would be good options.
Old 03-25-2004, 07:51 PM
DenzSS's Avatar
Dyer is awfully good as well. Some of the best rods I've ever seen.
Old 03-26-2004, 12:11 AM
Slowverado's Avatar
what about the crower rods, any good?
Old 03-26-2004, 06:04 AM
LOnSLO's Avatar
The Dyers are an awesome piece. I opted for the Lunati pro billets though. 625 grams.
Old 03-26-2004, 08:39 AM
Cstraub's Avatar
You don't want to run Ti on a street engine. The negative about the rod is it is so ridged. You must have some about of energy abosorbtion with rod material so that "cushions" the power stroke energy and does not transfer all of it to the crank. Ti is run in the top classes but the rods are cycled as with anything. They are hard on bearings and need to be in an dry sump applicaton only.
I know Jager has taken 2 orders on LS1 rods, so 2 of you out there are running 430gm aluminums in your dailey driver drag car.
Chris
Old 03-26-2004, 09:26 AM
DenzSS's Avatar
Looks like we're in the same ballpark. I have a solid roller 408. No nitrous at this point, but it was built to hold a 250 or so shot.
The Pro Billets are a damn fine rod too.
Old 03-26-2004, 09:36 AM
Restricted User
CAT3's Avatar
Weight of the Dyers?
any links?
Old 03-26-2004, 09:37 AM
LOnSLO's Avatar
www.dyersrods.com
Old 03-26-2004, 10:14 AM
DenzSS's Avatar
What pistons and crank did you use? How about your valvetrain?
Old 03-26-2004, 10:23 AM
DynamicZ28's Avatar
what are the weights of the eagle and lunati pieces..I don't necessarily need an exotic billet rod. this isn't going to be a high horsepower app. just need a light rotating assembly
Old 03-26-2004, 10:34 AM
LOnSLO's Avatar
Callies crank, Diamond customs. Valvetrain is nothing special
Old 03-26-2004, 10:41 AM
DenzSS's Avatar
Well, we're right on par. Same for me. Only difference is the rods. I ended up with a good deal on my valvetrain, so I went with Jesel Pro Ultralights and Jesel lifters. Only thing that is a real pain is clearancing everything for the Jesels. Unpleasant.
Quick Reply: Lightest LS1 replacement Rod
