christiandoy
04-06-2012, 12:18 AM
Hey everyone!
My name is Christian and I am brand new to the forum.
I have just purchased my first ls1 block which came out of a 99 camaro and have huge plans for it.
What has already been done:
Head work:
241 heads
Hot tanked
Sandblasted them
Valve reseating and three angle cut
AFR dual valve springs rates up to .650 lift
Ls1 corvette rockers+shafts
7.375 chrome moly Texas speed pushrods
Block work:
Hot tanked
Comp camshaft 230/230 112 LSA 5.91 lift
Re-sleeved cylinder from wrist pin damage
Just a couple weeks in so I'm still gathering all my parts that I need
I have a long way to go but my plans are to order a 383 rotating assembly and over bore the block to 3.903!
Rotating assembly will be purchased in the next week or so
So to recap
First ls1 motor
Stroking it to a 6.3 383ci
Spending boat loads of money
:D
Any input or recommendations are welcome!
I will be doing an n motion single roller timing set as well as using ls7 lifters
Also plans for a melling high pressure oil pump
For those interested:
The rotating assembly includes an eagle forged crank,
Eagle h beam 6.125 rods with arp rod bolts, mahle 3.093 6cc pistons with rings, and all main and rod bearings!
The whole assembly comes balanced :D
I'll keep you guys posted on progress
And I will post a build thread when I have enough pictures to keep you guys happy!
Head work:
241 heads
Hot tanked
Sandblasted them
Block work:
Hot tanked
So to recap
First ls1 motor
:D
