Trans question for a 6 liter build
Old 04-06-2012, 09:24 AM
bad_408_vert's Avatar
Default Trans question for a 6 liter build
Hi all,
I want to put a 6.0 in my 2001 v6 camaro.
There are many aluminum/iron block motors out there so my question is how do I choose which trans do I go with that will handle the power from a 6.0 with a 10lb nitrous bottle.
Which transmissions will mate up to these motors from trucks or from GTO / c6 vettes?
I can go either way with manual or auto so show me the way:
Modified 4l60e or 4l80e or 6l8oe or a Modified T56?
Old 04-06-2012, 12:51 PM
rp0029's Avatar
Originally Posted by bad_408_vert
Hi all,
DO NOT go with a 4l60e. It will break. 4l80e is most bang for the buck as it will not require separate controller - they are supposed to hold 450 ft/lbs stock. T56 is fine too. Depends on whether you want auto or stick.
Old 04-07-2012, 11:32 AM
Pocket's Avatar
4L60E with a few upgrades to handle the nitrous is the easiest. A stock 4L80E will do the job and then some, but is obscenely heavy and requires a few custom parts like harness/crossmemeber/floor mods/driveshaft just to get it in there
Any LSx trans will work aside from from corvettes, but even those can be adapted at a competent trans shop. If you plan to keep the trans mounted TA, you'll need a tail housing from a Fbody or GTO, if not the trucks and other IRS RWD cars will work fine. Column shifted vehicles will have a range switch on the trans that you wont use
Quick Reply: Trans question for a 6 liter build
